if you can do 1100 cas4 with 2.3v they are d9gkx
if you can do 1200 cas5 with 2.1v they are d9gmh
Paired my Teams with the UD3P and the DDR2-1333 drive strength profile. The subtimings were very loose as set by auto in the BIOS (PL 11, tRFC 70 :eek:) but it's 32M stable, although I still needed almost 2.60V to do it.
Team Xtreem PC2-6400 D9GHM @2.28 volts
http://img128.imageshack.us/img128/3299/1333ramxp3.jpg
My Geil DDR2-1160 C4 kit only needed 2.40V for 650MHz :D
My Geil kit, which was mediocre in my other boards, is really responding to the UD3P and its OC profiles :eek:
@Shiranui Gen-An
Since u seem to be overclocking ur RAM good on ur UD3P, could U please post ur BIOS settings for on the above overclocks?
I just tired some more RAM overclocking, but I still haven't been able to load Windows at 1400MHz or anything over 1333MHz. I got.
http://valid.canardpc.com/show_oc.php?id=481960
With 2.7v.
Like 1300MHz 5-5-5-15 works at 2.4v, but 1400MHz 5-5-5-15 at 2.7v doesn't? Even running the timings at 7-15-15-63 didn't help.
I think you will need a higher NB voltage to do that, 1.32v seems to be a bit low, but I'm only speculating.
I also own that board since last weekend, but I haven't been able to achieve anything worth mentioning up to now. One thing to note is that 600MHz is incredibly easy with this board. However, I guess I will need two more weeks to learn all the new feature of an Intel board... so many new options...
ballistix 5300 (D9GMH) @2.26v
http://i209.photobucket.com/albums/b.../600-500-1.jpg
I have a new stable FSB of 1900MHz (475MHz) which means better memory speed of 950MHz, however I've had to increase vdimm for CAS4 and I don't know what to go for:
950MHz @
4-4-4-12 needs 2.125v
4-3-4-10 needs 2.15v
4-3-3-10 needs 2.175v
I currently have it at the tightest settings I can get without going to 2.2v, but I really don't want to lose these sticks of ram so maybe I should loosen the timings...but what a waste of D9 lol - I bought them to PERFORM! :D
Code:*******************************************************
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: Auto
CPU Clock Ratio ......................: 8x
CPU Frequency ........................: 3.55GHz (444x8)
************** Clock Chip Control **************
>>>>>> Standard Clock Control
CPU Host Clock Control................: Enabled
CPU Host Frequency (Mhz) .............: 444
PCI Express Frequency (Mhz) ..........: 100
C.I.A.2 ..............................: Disabled
>>>>>> Advanced Clock Control.........: [Press Enter]
CPU Clock Drive.......................: 800mV
PCI Express Clock Drive...............: 900mV
CPU Clock Skew (ps)...................: 0ps
MCH Clock Skew (ps)...................: 0ps
*********** DRAM Performance Control ***********
Performance Enhance...................: Standard
(G)MCH Frequency Latch................: Auto
System Memory Multiplier .............: 3.00A
Memory Frequency (Mhz) ...............: 1332
DRAM Timing Selectable ...............: Manual
>>>>>> Standard Timing Control
CAS Latency Time......................: 5
tRCD .................................: 5
tRP...................................: 5
tRAS..................................: 15
>>>>>> Advanced Timing Control........: [Press Enter]
tRRD..................................: Auto
tWTR..................................: Auto
tWR...................................: Auto
tRFC..................................: Auto
tRTP..................................: Auto
Command Rate (CMD) ...................:Auto
>>>>>> Channel A Timing Settings......: [Press Enter]
Static tRead Value....................: 7
tRD Phase0 Adjustment.................:Auto
tRD Phase1 Adjustment.................:Auto
tRD Phase2 Adjustment ................: Auto
tRD Phase3 Adjustment.................: Auto
Trd2rd(Different Rank)................: Auto
Twr2wr(Different Rank)................: Auto
Twr2rd(Different Rank)................: Auto
Trd2wr(Same/Diff Rank)................: Auto
Dimm1 Clock Skew Control (ps).........: Auto
Dimm2 Clock Skew Control (ps).........: Auto
DDR Write Training....................: Auto
>>>>>> Channel A Driving Settings.....: [Press Enter]
Driving Strength Profile..............: OC-1333
Data Driving Pull-Up Level............: Auto
Cmd Driving Pull-Up level.............: Auto
Ctrl Driving Pull-Up Level............: Auto
Clk Driving Pull-Up Level.............: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down level...........: Auto
Ctrl Driving Pull-Down Level..........: Auto
Clk Driving Pull-Down Level...........: Auto
>>>>>> Channel B Timing Settings......: [Press Enter]
tRD Phase0 Adjustment.................: Auto
tRD Phase1 Adjustment.................: Auto
>>>>>> Channel B Driving Settings.....: [Press Enter]
********* Motherboard Voltage Control *********
Voltage Types...........Normal..........Current
>>>>>> CPU
Load-Line Calibration.................: Disabled
CPU Vcore..............1.31250v......: 1.50000V
CPU Termination........1.200v.........: 1.300V
CPU PLL................1.500v.........: 1.500V
CPU Reference..........0.780v.........: Auto
>>>>>> MCH/ICH
MCH Core...............1.100v.........: 1.360V
MCH Reference..........0.800v.........: Auto
MCH/DRAM Ref...........0.900v.........: Auto
ICH I/O................1.500v.........: 1.500V
ICH Core...............1.100v.........: 1.100V
>>>>>> DRAM
DRAM Voltage...........1.800v.........: 2.480V
DRAM Termination.......0.900v.........: Auto
Channel A Reference....0.900v.........: Auto
Channel B Reference....0.900v.........: Auto
(double post I know, but I'm lazy heh) Try just leaving the MCH reference at auto, thats how it always works best for me, and to start with set NB and CPU clock skew both to delay by 100ps, this should keep you stable till around the 575\600 FSB realm, but of course theres no guarantees as everything behaves differently.
I don't know of any ram modules other than Cell Shock which use thermal paste, which is they only reason that I felt I could safely remove the heatspreaders. I know that there are ways to get the heatspreaders off, but my mate has an OCZ Reaper D9 kit and the heatspreaders are practically glued to the ICs. Not so sure about Ballistix.
I played a bit with my new kit that I got off ebay last November, took so long to be delivered...
So now I have 6GB of D9 on my UD3P:
At first stock settings of the Mushkin kit ( DDR2-800 ):
http://img440.imageshack.us/img440/8...00crubazr9.jpg
By don_dan at 2009-01-18
Then a slight overclock to DDR2-1066:
http://img440.imageshack.us/img440/7...300crubrz7.jpg
I just started playing with this kit, so more to come next week! If anyone can share results or tips for this kit it would be appreciated.
I just got another Cell Shock kit from ebay, this time the PC6400 kit which uses D9GMH.
I'm gonna use 4x1GB with GKX and GMH together - might this cause problems? I haven't seen or heard of anyone using the different kinds of D9s together. If the GMH aren't so good, I'll buy a nice 2x2GB kit and be done lol. :D
Well I'll prob go back down to 450FSB for 4x1GB, so I'm looking for best timings at 900MHz no higher than 2.1v. My GKX can do 4-3-3-9 (tRAS at 8 is unstable) so best case scenario would be 900MHz 4-3-3-10 or thereabouts. I'll test the D9GMH on its own first, of course. :D :up:
Having a bit of fun with my Team Xtreem 1200 kit and my DFI LT P35 T2R.
^ Nice work. Wouldn't mind one of those boards.
Gskill PC8500HK (DGMH) on nforce650i:
vddr@2.35v
http://img179.imageshack.us/img179/5081/snap1cj2.jpg
