Originally Posted by
Broly
Lol says the guy whose running 2 gigs of it.
Go look at the 4 gig kit you fool. You'd realize JEDEC specifications designate that at a stated voltage the ram must produce a certain speed.
To be JEDEC certified at 1333 mhz compared to 1066 mhz means that they're both on the same voltage designated by JEDEC themselves and produce that speed.
If you think that JEDEC 1066 mhz ddr3 and JEDEC 1333 MHZ ddr3 aren't night and day difference for overclocking, you sir are mistaken. That is why Corsair's DHX XMS3 kit that is 1600 at 7-7-7-20 costs nearly 800 dollars, because the IC's used are much more expensive.
You run 2 gigs, and thereby have lost your merit to speak. It's not hard to run 2 gigs of ram and overclock, but double density ram is proving to be a problem. Don't believe me? Read around on some forums and you'll see that just because 2 gig kits and 4 gig kits produce the same ratings (in this case patriot's 2 gig viper 1600 kit is 7-7-7-18 and mine is 7-7-7-20 at 4gb) it doesn't mean that they're going to overclock equivalently.
Also, you're the rookie who registered just, 45 days ago? In my opinion your credibility is shot from saying I know nothing, when you sir are the idiot who doesn't understand that 2gb modules of DDR3 that are good are expensive, and hard to find. Which is why when Patriot sells 1066 mhz JEDEC memory overclocked to 1600, it's only a handful of a field of them that get this rating. The problem? Run them in sync mode with no tax on the CPU (There is no tax on the CPU if you had a qx9650 you'd know that you can change the multi, so running 7.5x400 means I"m running 3 ghz and I was getting therms around 45-50 degrees UNLINKED with my ram at 1600). When I start to link stuff, the ram goes haywire. One can usually tell if the BSODs produced are by ram or by CPU, and in this case it was my ram. Data corruption that wasn't really there occured when I'd boot it'd say files are missing. When I change it back to stock settings, then everything was dandy.
You should stop insulting people and read more before you start posting about your leet q6600, you're going to lose credibility fast. YOu should be more mature too
