A day after updating to 602 bios, I got a black screen while playing a game. Event Viewer shows: "The driver nv4_disp for the display device \Device\Video0 got stuck in an infinite loop"
Research indicates that this is usually a mb bios, memory, graphics card issue. It's usually not the video card, but an interaction between the video card and system memory. Remember, XP can Address a maximum of 4GB, and that includes your video card memory. That's why you see less than 4GB of memory in Windows (usuallly 3.25 to 3.50 GB reported in Windows).
I've been playing the same game everyday, so since this problem happened for the First time after the bios update, it may be the bios. Memory checks out fine with MemTest for 8 hours.
If it happens again, I will go back to 601.
I also decided to bump my memory voltage from 1.9 to 2.0v (The G.Skill memory calls for 2.0 ~ 2.1). Since the P5E MAY overvolt by .05, I should be within spec.
