First thing I did when I got home was update to the latest BIOS. I like the small tweaks they've made.
Went straight to 295x12 3550Mhz and it crashed PrimeStable almost immediately.
I increased vcore and NBvolt a little and changed to 3510Mhz and it was Prime stable 6.5 hours.
Funny thing when I got up this morning to check it I turned my LCD on, moved the mouse to turn off screen saver and when the LCD displayed it showed a BSOD that only occured moments earlier. It seems coming out of screensaver caused the BSOD. Moments before I turned on my LCD I checked my CPU useage with my G15 Keyboard and noticed all cores running 100%. CoreTemp logs confirmed it had been running for 6.5 hours.
Funny that. I'll be sure to turn off my screensaver tonight.
Anyhow to me this confirms it was not my PSU that caused the shutdown. With increased voltage to CPU and NB, the Galaxy had no problem running Prime for 6.5 hours overnight. From memory vcore was 1.4625 and NB was 1.4375 (close to anyway).
NB temps are screaming at over 70degrees now, so I'll be rotating the NB HSF 180 and will put less TIM on it soon.
I'm still happy with progress. GTL tweaks will need to be made soon.
Considering I haven't lapped my CPU and I have a fair bit of headroom in my vcore to play with, I still have a bit to go :)
NB: I really enjoy the new option with the latest BIOS to modify the CPU temp delta. Now, on load Guardian is the same as Coretemp for me :) gg DFI
On another note, looking through the hwbot rankings, my 1024M and 32M wPrime times are the fastest for my CPU frequency. Infact my times are faster than others that run their QX6700 at a higher frequency. This is with a multiplier of 12, and 'basic' RAM timings of 4-4-4-1T, using Vista :D
I don't know what motherboards or OS the others are using, but this MB damn fast :D
