i've noticed that when my cpu frequency starts to flucuate thats also when it becomes unstable.
Ok. Manufacturers not helping with the "on the edge" overclocks in that regard.Quote:
Originally Posted by burningrave101
This is what I'm thinking. It seems that when the voltage drops it fails prime. Even if I bump it up one digit higher, it drops to the previous setting, fails.Quote:
Originally Posted by itznfb
It would be great if one would hit 3GHz on 1.375v but i find it highly unlikely. Just because its capable of hitting say 2.6-2.7 on a lower than stock voltage doesn't equate to it hitting 3GHz on 1.375v. The chip may respond better to lower voltage at certain clocks but will cap out at the same frequency as the others no matter what voltage you use.Quote:
My clock frequency constantly fluctuates in CPU-Z although its normally by <1MHz and it never results it me failing Prime.Quote:
@burningrave101 we've already seen a few chips hit 3ghz on 1.375, and i'm not talking about frequency fluctuating in cpuz, i'm talking about when the HTT starts to flucuate during Prime testing. this results in teh frequency shown in Prime to report say 2912-2915, generally when this happens if you increase your HTT you will be unstable in prime.
Who has hit 3GHz on 1.375v Prime stable? I dont see any on the chart.Quote:
And the other guy was talking about CPU-Z, not SP2004. Thats why my response was concerning CPU-Z.
i believe repo has, and there are a couple guys on other forums that have. and you don't see any on what chart?
yea, repo has 2hr prime stable 3ghz @ 1.375
my chip boots into windows 3ghz @ 1.35, but i can't keep the temps low enough to stability test it.
Yeah i believe that was on his 0608MPMW and unless your looking at a different screenshot then i am it says 1.375v in CPU-Z which would mean his actual vCore is at 1.4v or a little higher. I'm sitting at 1.4v actual right now and CPU-Z is saying 1.360v.Quote:
generally cpuz show the voltage higher than what is set in the bios. my cpuz is dead on to what i have in the bios.
and if you're talking about the "chart" on the first post, there are no results on there because i haven't put them on there. they will be on the next update.
It will differ from board to board because of the different motherboard sensors but it usually always reports low on the DFI NF4 boards from what i've seen. Its usually .025-.04v for me on my Expert board. If you will take a DMM and measure the vCore on a DFI board it should be near exact what you set in the BIOS and reporting a little lower then that by the sensors. I have the vCore set to 1.4v right now without special and its reporting 1.360v in CPU-Z.Quote:
Put CCBW 0609FPAW on the avoid. Mine is nothing but a POS (Opteron 170)
http://www.atotchat.org/~montavis/dm.../firsttest.jpg
I lost another img where I did prime for 32 hours on 2.5ghz, same settings using SP2004.
I tried 2.6, and that took 1.475 volts to stabilize, but no screenie cuz I wanted to keep going.
2.66 ghz took up to 1.55 volts for prime stable. Temps were around 55, so I gave up.
Cooling: XP-120 + Panaflo.
Core 0 was very weak.
I'm now testing a 0551 UPMW I got from Monarch today. What are you guys getting from Monarch ATM? (Opteron 170). I know 610s are coming in for 165s, but what about for 170s? Was I just the unlucky few that got sent a 0551 while everyone else is getting 610s?
So far 2.5ghz is prime stable at 1.35... will keep going and will post screenies
could have told you that before you even started :p:Quote:
Originally Posted by dmo580
Is it me or the new opterons overclock like crap? :slapass:
guys, ever heard of CCB1E 0607MPMW ?
is it a gem, or a stinker?
thx:)
Perhaps its a typo, ccb1e 0608mpmw exists.Quote:
Originally Posted by pershoot
hmm possibly. i gather most all CCB1E's will clock well toward 3ghz.
Check the first page of this thread in the table :cool:Quote:
new optys are the best overclockersQuote:
Originally Posted by Malkec
4 x 1mb spi :rolleyes: CCB1E :banana: air cooling ;) :slapass:
Originally Posted by Rufus7
hell i cant get stable at 2.8ghz without a 1.45vcore and above.
i cant even get pass 2.9ghz on my 0550vpmw
btw is a 0550vpmw ccb1e opty 170 cold bugged ?
It may be a better chip because of the CCB1E stepping but for the most part the 0607MPMW chips have overclocked poorly.Quote:
But is any new stepping better than ccb1e series?Quote:
i would like to know whether is the 170 ccb1e 0550vpmw cold bugged ?
getting a phase change soon. some tell me it is some tell me it isnt...
