Test 3 models of Z68 boards with the following BIOS:
1.) Z68X-UD7 with BIOS F10
2.) Z68XP-UD3 with BIOS F9g
3.) Z68AP-DS3 with BIOS FB
Our test results:
1.) Press CTRL + ALT + DEL keys when during boot up or in DOS mode >> Cannot see “continuous reboot loop”, nor “Waiting for ME ready”, nor “system overclocking failure” message. The system just reboot fine.
2.) Press the Reset button
A.) Press the button quickly and release immediately >> Cannot see any issue.
B.) Press the reset button for one second or so (This is not normal behavior.) >> System will shut down, and then power on by itself. Then the “Waiting for ME ready” message appears and then system will shut down and power on by itself again. Sometimes, it will show “System overclock failure” message.
Moreover…
According our testing before,
the issue of “continuous reboot loop” can be fixed by flashing the Backup BIOS with the same version as the main BIOS (latest one).
We Flash the Backup BIOS with the same BIOS version for the main BIOS version before test.
So be careful with that reset button and it should also work properly now too! But I still say avoid if/when possible :D
