I give up on RAM overclocking. No matter what I try my UD3P and P5E could not do over 1333MHz. Even 3v didn't work, i'v tried every other reference or volt.
So I give up.
So I give up.
dont give up boy :D
fight until death
I did (kinda) i don't know what else to try :shrug:.
When you say "do over 1333" do you mean simply being able to boot and bench, or are you looking at some semblance of stability??
I meant being able to load windows and bench.
Giving up is a sign of weakness... :p:
I know, i'v spent weeks tho.
If I could see someones BIOS settings (and I mean all the BIOS settings) for 1400MHz on a UD3P/R (that can at least run Everest benchmark) i'd give it ago. But I haven't found any.
Could be because I have a 65nm quad and its to hard on the MCH to run it and the RAM?
PS i'm getting a E8500 soon.
Its obvious, but have you tried a TRFC in the 45-60 range?
Yep its been above that too.
I tried maxing out my primary timings (7-15-15-72), not sure about the last one, but something like that and it still didn't help.
Also I can even do 1066MHz @ 4-4-4-12 @ 2.3v, but on my P5E I could do 1111MHz +.
Probably DIMM power regulation implementation is a bit flaky then.. a good BIOS could probably top you up to 1080-1100, but something in hardware deffinately doesn't seem as strong.
My CellShocks sticks are fine. On my P5E any 1 stick could do 1300MHz 5-5-5-15 W/ only 2.21v +- 0.02v (windows).
Maybe I have a massive vdrop on my RAM :confused:.
Anyone know a program to measure vdimm on UD3P?
Possible. Like I said, something in hardware deffinately isn't as strong. Time to bust out the multimeter methinks :D
Stop buying so many sticks of RAM then :p:
LOL
Atleast its not as bad as my -$2000 back in 06 :(.
I'm going to give it one last go in a few hours.
Just have some questions.
1. DRAM Clock Skews, do they help? If so what should I set them to for 1400MHz +
2. Is there any other volt but MCH and vdimm i'll have to adjust?
3. Data/Cmd/Ctrl/Clk Driving Pull Up Level?
4. Data/Cmd/Ctrl/Clk Driving Pull Down Level?
5. tRD Phase 0/1/2/3 Adjustment?
6. Trd2rd/Twr2wr/Twr2rd/Trd2wr Different Rank?
I'v tried playing around with these, but its hard when theres lots of different options and I have no idea whats good/bad etc?
They do help, but its all experimentation to see what works and what doesnt. Especially with skews and pull up\down levels. For sub timings try something like 42-4-8-4-4.
OT: these Team Extreem sticks are D9GMH: http://www.memoryc.com/products/desc...kit/index.html
http://ceemic.pri.ee/hardware/team_xtreem.jpg :)
I'll give a shot later...
Cellshock D9GKX this time higher MHz at CAS5, still 2.2v - love it :up:
http://i293.photobucket.com/albums/m...005_5_5_15.png
I have two pair of double-side 1GB Tracers. The one w/o the clamp. Which version of D9 are they or do I have to tear off the spreaders to find out?
