You just found 1:cool:- still good find, remmeber Dave said He was searching high and low for that 1
Jeez Dave were you sleeping and did you hear Bail w post or something;)
Really? i thought 2.16ghz is the highest. What is the sSpec for the 2.3ghz?
edit:
http://www.cpu-world.com/cgi-bin/SSpec_Chart.pl
i can't find any 2.3ghz here.
That is weird. According to the intel processor sSpec finder, there is no 2.33ghz intel xeon lv.
http://processorfinder.intel.com/Lis...528&SearchKey=
Filter by package: Micro-FCPGA
:confused:
edit: nvm, SL9HM did not come up in that list as well, so i guess there are 2.33ghz sammys.
Well, the specs listed under "NEXXUS 4820-BB" are exactly described as a sossaman. On the other hand, under "NEXXUS 4820-AL", they listed the model of the Xeon LV processor which is 64bit capable.
Hmmm, one thing caught my attention is under "NEXXUS 4820-BB", they listed the 2.33ghz sossaman is 32gb and up to 64gb memory capable. Don't you think for a 32bit processor would be able to use 64gb of ram?
The 5148 cpu's they list for that are the low voltage woodcrests, like the orginal C2D's..E6600's
It's a cluster server so interlinked it could use that much memory.. It's like a baby Cray in some ways..
16 sammys interconnected would have some interesting computing power and in that case would be decent..
Time for bed and congrats on your find..
You can PM me how much you stole it for!:D
Multiple Sammy's available on ebay here:
http://cgi.ebay.com/Xeon-dual-core-L...3%3A1|294%3A50
$50/piece, but I've seen worse.
I'm working on a case design for my sammys. Would be much easier if I could use one PSU to run both of them. Has anyone done this before? If I split the 24 pin between the two boards, and I hit the power button of one, would both come on together? If I tell one to shut down, does it shut both down or just end up restarting the one, or....? How would this work? Does anyone know? :shrug:
How true.
I'll just shoehorn both PSUs in this box then :D
Ran into an snag. Everything was fitting perfectly in this box until I realized I need a spot to put the hard drives. With one PSU there would be enough room for the drives but with two PSUs it is a struggle. If only this was about 2 inches taller...
I did a google, Looky I found CyberDruid posting how to do it - with the power up questions I had answered! :D
http://www.overclock.net/faqs/112866...ply-power.html
