It where the 9600's dying immediately the 9500's required more time. Can be that issue is somehow related to the 790FX chipset and that's why I had no problems with 2.2-2.25V on the M3A.
The chip is rated for max 1,5V and 70°C. It's really odd that he died at ~50° and 1,375V. But nevermind i joined the 9600BE-bingo, just receiped the confirmation that the 9600BE i ordered few hours ago is already on his way. With a little luck i'm on k10 again tomorrow. :cool:
A DMM with a temp probe just arrived. If i put the probe on the BE2400's IHS I measure ~27°C. Smart Guardian reports 42° C. That's only a 15° difference whould mean my phenom ran at 85°C minimum when SG reported 100°C.
Must say I expected prime to fail before the cpu dies if that high temps where the cause.
Once we had an air con problem on a hot summer in our server room.
CPU temps where above 85° every now and than case temps above 60° where also no rarity and the servers powered off on a daily base. A few HD's died but no cpu or other component.
