FIREWIRE PROBLEM & cooler compatibility...
hi bros out there,
Anyone of of u guys using the P5W DH DELUXE with sycthe ninja plus??? Is it compatible???? UIRgent
i've having this problem all my USB ports can only be used when only i remove the firewire port. Y is this so??? how am i gonna use my firewire port then.
if i were to install the firewire port only myI/O panel USB can only be used... any of u guys having the same problems,..
REGARDS
SLI and 'missing' RAM quirks
Just tried out SLI (2 x el cheapo 7300GTs) for the 1st time on my P5W the past week and noticed certain strange quirks about RAM being reported differently by the mobo, Windows and CPU-Z.
Installed is 2 x 1 GB sticks = 2048MB - everything reported OK without SLI. With SLI, the mobo POST reports as 1920MB (OK, kind of expected), Windows as 1.6GB (WTH, @%%!) while CPU-Z maintained at 2048MB.
Is something being configured wrongly? Looked around but can't seem to find a good answer, TIA.
http://img115.imageshack.us/img115/3...pertiesmk1.pnghttp://img115.imageshack.us/img115/8917/cpuzramih2.png
PS: regarding the RAM timings - still have to run my RAM at SPD on my P5W mobo till now.
