Doe's anyone have MSI x800gto?
http://www.msi.com.tw/program/produc...il.php?UID=712
It has the similar PCB to x850xt, and cheap price there, but someone unlocked this card?
lol nice scores for a card that costs 2x cheaper and overclocked can reach 7800gtx (more or less default) scores .
:toast:
well i finallyy had enough with the air cooling on the gto2 soi dug out my water block, bumped vgpu to 1.58 (droops to 1.56 load) and got up to 653 in ati tool before it froze my pc, did a quick 05 at 640/640 and got 75xx and about 500 extra in 01 , forgot to disable lan and bluetooth though so may of got another 1-200 pts.
temps are about 50c loaded now with the waterblock, thats with my 146 opty in the same loop which also reaches 50 fully loaded now, ran spi 4mb and ati tool on scan to get a good hammering for both and they both sat at 50c lol, think im gonna have to either upgrade to a tripple rad or use a seperate loop for gpu.
What max vgpu should i use going by current temps??
will i get much better temps with a tripple rad?
What is the rest of ur watercooling system? :)Quote:
Originally Posted by pancake
mcw6002 cpu blockQuote:
Originally Posted by funkflix
hydor l30
asetek gpu block ( dont be fooled as its a asetek its just as good as the maze 4 i had)
crappy 2 x120mm rad that came with a asetek kit ( had 1/4" barbs i stuck 1/2" on, but the inlet hole is still small) 2 120mm papst fans
crappy asetek res with 1/2" barbs
Hmm...
My watercooling setup is
Swiftech MCR220 QP 120.2 radiator with 2 x Noiseblocker fans @ 1200 RPM
Laing D5 pump at #3 setting
AquaXtreme MP-05 Pro Limited Edition CPU block
DangerDen D5 GPU block
And i get load temps of 42 on CPU and 45 on my GPU (vGPU @ 1.6v). i'd recommend upgrading the pump and CPU waterblock maybe?
I think a goos triple radi external will give u much better temps, dunno if ur radi is already outside of ur case?Quote:
@K.I.T.T.
Do not really know the components u use, but is ur radi inside or outside the case?
My temps are about 25°C idle and 36°C load, with 1,68V Vgpu.
The Rad is outside the case, but is sucking air from inside the case. I think if i reverse the fans, i may get better temps. I get idle temps of 28*C on the GPU. As far as the CPU goes, i get idle temps of 34*C :rolleyes: Bad IHS contact for sure....Quote:
Yes, try to get colder air to the radi, it will give u much better temps i think. :)
My radiator is inside the case with fans sucking air into the case.
Whats a good double or tripple rad to get, want one thats not going to be restrictive like my current rad, and preferably not a heatercore
I do not know what stuff is really good in the us, maybe u start a topic in the watercooling section. :)
Or are u not from the us?
Originally Posted by Kasparz
I had it, it can't be unlocked, and its r430 so stay away can't even be OCed
no im from the u.k, looking at the thermochill pa160, looks like a bit of a beast considering the size, a tripple is only slightly more expensive but twice as big and then some, and temps arent much diffrence.Quote:
I may just see if i can get a cheap pump off of egay aswell and use 2 seperate loops for gpu and cpu
Well, this thread has gotten kind of long. I remember contributing to it in the 18-30 page region.
However, I tend to have a strange problem. The card freezes. Very very rarely in games, mostly in source, a few times in other games.
The screen turns black, sometimes freeze+artifacts.
Is it core or mem?
I think that this is much Core,Quote:
Originally Posted by KoHaN69
have this problem same in quake4, when I go down with little mhz no problem a frequency of mem was same.
I would vote for the core too. :)
http://img89.imageshack.us/img89/8224/img21411yh.jpg
my wallpaper;
http://img503.imageshack.us/img503/1076/opo0328a5se.jpg
Well, this is what my screen looked like once.
I was playing a game, and it froze and went black, so I alt+trl+del -ed
And the funny thing is that my PC was still working fine. The sounds were there, and I could blindly run programs.
I shut-down, and I could see that blu bar moving, (the win2k loading bar) as it was shtting down.
When I restarted, The red msg poppup up that the power cable was disconnected. But it wasn't. So I reconnected it.
And recently, It happend again. The screen went black, and floze and the last 1/3 of the second of sound looped.
i was not overcloked either of those times.
@ kohan....i'd RMA it it i were you.... check that the ram timings are correct first though :)
This is the highest i can get mine: http://service.futuremark.com/compare?3dm05=1881843
She hasnt got any more to give :(
kitt- u have the sapphire, i have the connect3D gto.
this happens quite rarely, and never in some games.
if i rma it, i would get the newer version, in which the pipes are locked
maybe try reflashing the bios? try different drivers and check if the HS is seated correctly :)
Maybe? Which one would you recommend?Quote:
Originally Posted by K.I.T.T.
r430 w/ 2.0ns mem i think.
the temps are idle 30c, it seated perfectly (MaxxxRacer installed it :D )
I have a GTO2 unlocked to 16 pipes coming. Will give it a shot :)
:confused:Quote:
Originally Posted by IvanAndreevich
Give what a shot?
I am going to vmod the :banana::banana::banana::banana: out of it and overclock the life out of it with a dual core opty @ 2.8 GHz and some fast RAM. Do some '01 runs.
INTERESTING read:
http://www.techpowerup.com/reviews/M...TO2Burstfire/1
Mad Moxx X800 GTO² Burstfire
