ok thx guys ill be hone around 4pm est time... heres a shot of my memory settings talk to you guys later....
thx perc,
thx perc,
Alright, first suggestions just to make sure all's stable....use a mem divider! Second...just set trc = tras + trp in the meantime (10 in your case).
Hey Perc how does this thing compare to running a x2 as I have order one and hoping to preform better than the x2 or is it about the same??
It performs differently....the X2 is a much better multitasker and better for things that are in fact SMP aware....the Opteron is better at benchmarks and non-multitasking.
I have both and I run my X2 for 24/7.
only 1 tip for youQuote:
Originally Posted by Perc
give some volts in cpu
i have 1 identical steeping and maybe yours need more to scaling
dont have afrayd, mine was at 1,8 and dont burn :D
look,i take off the bios 704, the same you have, because this bios limit the volts to something like 1,7xxvolts and hi need more to brake my records
now i am using bios 623-3. more vcore and the memory table is better
WELL??? :slap:
good luck M8 :clap:
2,951Gig 1,312Vc Aircooled IHS ON CABNE 0530APMW 146 Opti 7H Prime Custom
Ambient 14°C-17°C
[img=http://img413.imageshack.us/img413/9552/2951mhz1312vc7hprimecustom2gq.th.jpg]
Here my opteron 144 apmw 0530. Without heatspreader and cooled by water...
http://www.forumdeluxx.de/gallery/da...5302870S16.JPG
How about more volts??
I can buy a Opteron 148 with core CABYE.
Are they all 0528GPMW??, didnt ask it.
I analysed this topic and what i see are the following core/week and stepping:
Opteron 144: CABNE 0530APMW, CABGE 0536VPAW and CABYE 0536GPMW
Opteron 146: CABNE 0530APMW, CABGE 0534SPMW
Opteron 148: CABNE 0528GPMW and CABYE 0528GPMW
Opteron 150: CABGE 0534SPMW
went to bed last night with the opteron ~1-2min prime95 stable at 1.5v, 2724mhz, running cpu burn-in. woke up and could get it to just under 2.8ghz, load temps didn't change. i'm at 2.82ghz or so now. i should bump up the volts to 1.6v.. i know my water can take it :DQuote:
Originally Posted by Vapor
Is there anybody, having a CBAYE 148 0536 GPMW ??
Tomorrow, i´ll get one of it. Hoping for well results... :stick:
free
Don't know, never see this on any forum.Quote:
Originally Posted by freestylercs
Opteron 144 CABYE 0536 GPMW are average clockers, worser then the 0530 and 0528...
Let us know, plz
148 CABYE 0528 GPMW is pretty good. Have not been able to complete 32M at 3.5GHz yet. Requires too much VCore for my cooling. Will probably move to air cooling this weekend.
http://img409.imageshack.us/img409/4274/347132m0ku.jpg
I know dude, but the 0536GPMW was average on the 144.Quote:
Originally Posted by sierra_bound
Week 0528GPMW is :toast:
all us guyz over here in aus are getting the Opteron 144 0536GPMW steppings....
none of them can do 3ghz on water *yet* but are very close indeed.... (29xxMhz)
im getting two tomorrow hopefully they are a decent week, if not i will have to deal with 2.9ghz :)
hopefully my lapped TT Big Typhoon will do the job properly!!
ya, ill do.Quote:
Originally Posted by kakaroto
by the way , here´s my new 144 0530 APMW 0081 Batch
http://mitglied.lycos.de/freestylerc...,48V%2032M.JPG
free
I already mailed tons of stores and the only thing they have all got is, cabye 0536 gpmw :confused:
Have you asked alternate.nl?Quote:
thats the stepping ill get tomorrow. 148er.
free
No, they have got the 148 at the moment, But I thought they didn,t to these kind of requests.Quote:
I called, they have CABYE too, but did not asked the week etc. which shops did you asked?Quote:
last week i pre-ordered a 146 @ alternate.nl , hopefully they will get them in stock soon :D
I'm affraid when I get mine it will be from a crap step as usual... Anyway maybe some luck with a 148 one!
Your on watercooling right?Quote:
Can you please tell me your load temps?
yeah all the CABYE 0536GPMW CPUs seems to be similar to mine.....results posted a few pages ago...............here is another which is a bit better.......Quote:
Originally Posted by Catalyst2211
there are a few which are stresscpu stable a smidge under 3GHz
