Originally Posted by EnJoY
Yea but it was a GREAT idea! And we want you to know we appreciate your efforts. This thread helped me, and I'm betting it has helped lots of others too.
He's not faking anything, memclk freq = 200 which means no divider is being used. :slap:Quote:
Originally Posted by varzmaster
You need to do a better job of reading screens, dude. Check where it says "RAM Freq". Or do you know how to read? :rolleyes:Quote:
Can we have some of what your smokeing :spill:Quote:
Looks Like a stright 304 Mhz to me. were do you get the 240 shizzy ?????????
Have you tried your 4000 gold on the fx? Just wondering how much higher they will go with the better controller.Quote:
Originally Posted by Major
I don't know if it's been mentioned here before, but there are certain bugs where 1gb sticks will be recognized running the wrong speed:
http://img381.imageshack.us/img381/5420/3304gq.jpg
I don't have the OCZ anymore ;)Quote:
Originally Posted by dogsx2
There were no bugs involved in my SuperPi run, unless the BIOS itself is bugged. The memory speed (304) was set in the BIOS with the 200MHz divider. As soon as I booted into Windows, I ran SuperPi. Did not use Clockgen or any other overclocking tool in Windows. The dude from Romania seems to think Tref is the same as a divider. :rolleyes:Quote:
Originally Posted by s7e9h3n
Woot! I have 8th place all to myself! heh
I know my memory can go higher, but my CPU says no.
Awesome overclocks everyone. Please forgive a completely newbie question, but where do you guys get your BIOS updates for the DFI series boards?
Man, I don't know about any PQI Value RAM, there're PowerMemory or TurboMemory, here's the link to PQI:Quote:
Originally Posted by DltdApS
http://www.pqimemory.com/
if you can't tell me what exactly is written on the stciker on the RAM :slapass:, point me plz to the memory on the site, that is like yours.
Thx.
Originally Posted by MoToR
the part number is : MD441GUOE
you can see here : http://www.pqimemory.com/power_memory.asp
Drop your multipier and push the memory higher.Quote:
Originally Posted by Jame5
I look for bios updates on the Techpowerup site here.Quote:
Ah, thanks, damn, I have tested 6 sticks of that RAM. Time to think "OCZ", they always showed good compatibility with my board.Quote:
:brick:
Not to be rude, but if other people are consistently getting higher OCs with the same ram, then your board is the issue here. :(
I loved my P4C800-E Dlx, but it is doing your RAM a great injustice it seems. :(
Could be cheaper to keep your current RAM and update rest of system?
Good luck! :)
Noob here, please be gentle. I read most of this thread, and am now feeling dazed and confused.
I want to have 2 x 1GB sticks, as I have been unable to get far with my 4 sticks of 512. System: San Diego 3700 on Soltek K8T-939pro, I'm able to run stable at around 2600 (240x11) and am pleased with this. Have Corsair XMS 3200C2 that just won't go past 220 no matter what I do, whether I use 2 sticks or 4, 218 is about the limit. So, I'm looking for 2 sticks of 1024 at a reasonable price that will run at the 1:1 divider on this board (anything above 230 will make me happy). I do also have positive dividers available, so I can go higher than HTT if I want. (216, 233 and 266)
Please advise on the most likely sticks for my needs. The Skill 3200 looks to be a decent value, or should I go for some 4000? I really want to find something that will run at 2.5-3-3-6 if possible, I see some real benefits with the tighter timings.
Nutshell:
2 sticks of 1GB
Must be able to run at 240+ at 1T 2.5-3-3-6
Reasonable cost.
Anybody wanna buy 4 x XMS 3200C2 512MB ?
Your first investment should be a DFI NF4 Ultra-D. You could even wait for the new revision coming out later this month. Secondly, Ballistix are around $300 now, and they truly outperform every other stick on the market, so I can only justify getting them even if they are $50 more than a lesser set.
Thanks for the link gundamit.
There's a new revision of the DFI coming out?!? Sweet.
Ye, I came to the same conclusion. Yet, I don't want to upgrade at the moment, and I want to just find a compatible RAM for my FSB 282MHz 1:1, 5:4 or 3:2, I don't care.Quote:
Originally Posted by aresaid
http://www.xs4all.nl/~famchow/Memory...448_SPI32M.JPG
G.SKILL PC4000 2GB HZ
CPU-z verified link please Kakaroto. :)
Anybody heard how these G.Skills perform?
http://www.newegg.com/Product/Produc...82E16820231024
http://valid.x86-secret.com/show_oc?id=39607
new results for 2.9v...
Originally Posted by ElAguila
cl2.5-3-3-6 @ 240-255 mhz
cl3.0-4-4-8 @ 270-290 mhz (just 2 posts above your post ;))
Brain lapse on that one.
I guess I should toss some results in the mix. I haven't had time to complete testing yet, but here's my GSkill HS @ 2.7V:
http://img3.imageshack.us/img3/4996/...25spi1m8zx.jpg
