Why skip when you can have both? :D
Now help me out bro hehe.
You don't need raid when benching :DQuote:
Originally Posted by vegeta
neither do i surf the internet while benching ;)
guys,
i'm planning to buy P4GD1 soon..
what would be the max vcore, max vdimm after ct-479 is installed ?
the multiplier will be fully unlocked right ? :confused:
thanks in advance.....
max vcore, through pinmod is 1,8V, max vdimm depends onboard (or mods you do) and multiplier can be set with EIST.Quote:
Originally Posted by dinster
Have you already found this review by Kamerat?
http://home.no.net/comerade/pc/p4gd1.html
thanks a bunch !Quote:
Originally Posted by Jack
i thought multiplier is unlocked in the bios as well :mad:
only P4GD1 suffers this problem ?
don't know... you could PM Charlie for example.
He has that board already and he can probably tell you :)
The P4GD1 got locked multi in bios.
http://img256.imageshack.us/img256/2...95783jv.th.jpg
I think I’ve reached the max fsb with original vcore. Instability at 170 even with vdd at 1.8V. I’m using the beta bios 1009 in a p4p800se, mp working fine. Hadn’t try vcore adjustments because still using the asus ct-479 original cooler. I'm wishing to go water in a near future. Thanks for all tips. :D
With 1006 bios as well?Quote:
Originally Posted by NiCKE^
Try using the old ASUS Afudos file from Tony (aka. Bigtoe)here ... you have a spare BIOS chip or BIOS saver?Quote:
Has anyone tried mounting an XP-120 on the CT-479 yet?
Yupp but I cracked the core so badly that my max clock got decreased with 80mhz :(Quote:
Originally Posted by masterofpuppets
I was dumb enough to mount it without pads so I can only blame my self.
I didn't get any good contact either.
MrLobber, yes P4GD1 is fully locked
Urlyin, I don't need to cause I could boot with the adapter :D I got a 16 bios or something in it and it worked flawless :P
i am at 2.6ghz 217fsb with my 730 cpu, what do i need to post to be added to the list?
Yes. Removed the clips, dremeled the edges off the bars they had rested on and mounted them again underneith the bars with a couple washers each. Mounted about eight times. Chipped core second and fourth time. Got a heatspreader off a 1.8a now, but I've already moved to a zalman so I could put the xp-120 back on my A64s.
Stryg ... you can add Systool to apps ... it can change multi, FSB , memory timings and find max oc, plus monitors CPU temps from on board chip ... here. Works with my PM 750 and P4P800-E ...
Done :toast:Quote:
Originally Posted by Urlyin
applies to other Asus board as well ? (sorry for being noob)Quote:
:confused:
no, it does not
How can i do on a p4p800?Quote:
- Flashing to P4P800-E bios gives 4:5 and 3:4 dividers along adjustable vcore
Do i need that vcore u-wire mod to get higher vcore in p4c800-e dlx mobo?
i can put 1.6 in bios. and rise it whit vcore mod. but but. is that u-wire mod needed in that mobo?
Here is one tip on how to cool the dothan with water+pelt, very easy installation if you have the parts.
Swiftech MCW50-T with parts from this heatsink.
http://www.nordiccrew.com/crusader/MCW50_dothan.gif
The zalman 7000/7700 have the same parts, just rip 'em off. On top of the block, I have a rubberpad so that the retention wont slip. A 80W pelt should be able to keep the dothan cool dont you think?
My Dothan 730 stays onder 50 with full load with water and 1.6 vcore. Is this good? Or should it be lower?
I don't get why everyone's temps are sooooo high. I get under 30C @ 1.6V with a MCX159 chipset air cooler and only a few degrees above ambient on water.Quote:
Originally Posted by Razor_Sniper
Maybe the b1s run cooler than the c0s...
*checks*
well Intel says the C0s arelike 27W whereas the B1s are 21W, don't know if that effects it too much once o/ced.
Ok. My 730 boots whit 12x203FBS and its stable whit that. but thats all. i cant set any higher or its not stable anymore. i had used setfsb program to set clocks in windows. temps are 33C idle and 46 full load whit 1.6V.. i had tryed whit lover mems setting. still :banana::banana::banana::banana:ty clocking. any advices?
