woops I meant to edit.
Both are Good Motherboards..Quote:
Originally posted by Primal
After reading this thread I decided to buy A64 3200+ (moving from 2.4c @ 3.6)
So, what is the best stepping for this CPU?
One more question:
Should I go for the GA-K8N Pro or AN50R?
I like the AN50R because I can get up to 4V Vdimm with Mods.. But this Mobo has killed a lot of Cpu's. I blew up one of my A64's just by clearing Cmos :mad: But, This won't happen on an Unmodded Mobo..
The K8N pro, I think is a little more stable Motherboard out of the Box..
hi i will not be angry but can i have a answer please ? if it sounds bad sorry for my english
would you give an a64 2 volt for a long time ?
or how much would you give for a long time ?
hmm wich board ist the best for overclocking with an amd a64
i think at the GA-K8N Pro but i need good voltmods an i hope it will be about 300 fsb(HTT) with pc 4400 memory what du you mean can i get this result ? 300 fsb (HTT) ??
my best fsb with my k8n pro :
http://membres.lycos.fr/cpulloverclock79/391.5.JPG
nothin big i jus got my amd 64 to 2.3 ghz
2V is a bit high for 24/7. But if you have phase-change like your sig says, I think 2V should be fine.Quote:
Personally I have had 2.05 V, even with watercooling, but only during testing and benchmarking.
Asus k8v unmodded 1005bios, Corsair bh-5 blablabla..... Thermalright SLK-948U cooled with crappy 2800rpm fan :p:
Oh yeah, the chip is a DTR :)
24k run in 3dmark01 :banana: 510/365 unmodded cept cooljag heatsink.
Compare URL
Now I can whrite this, an bee on desktop pas 3400 Mhz.
The contact is better and the corevolt raised from 2.080 to 2.096 (2.112 safe)
a test at 200.00 with my shuttle AN50R and K8NHA Pro bios :
4*200 = 2366/2337
5*200 = 2955/2919
6*200 = 3150/3116
7*200 = 3138/3137
8*200 = 3132/3131
9*200 = 3123/3124
10*200 = 3143/3144
11*200 = 3154/3154 = 98.6%
TIMINGS : 7-16-(cas2)-2-2-5-2-1-1 1*1552 I believe
with my kingston HyperX PC3200 :
http://membres.lycos.fr/cpulloverclock79/297.JPG
Can someone answer my first question?
What is the best stepping for Athlon64 3200+?
(should i go on the CPU from the newest date?)
thx..
Nice overclock m8 are you running K8NHA Pro bios on your an50r ?Quote:
4*200 = 2366/2337
5*200 = 2955/2919
6*200 = 3150/3116
7*200 = 3138/3137
8*200 = 3132/3131
9*200 = 3123/3124
10*200 = 3143/3144
If so wich version :D
cpulloverclock does that shuttle board of yours have agp/pci lock?
nforce3 150 have apg/pci locked , you just had to set FSB to 201 in bios.
yes with a K8NHA eeprom and the last biosQuote:
no problem but 4622/4627 is with an An50R eeprom
exactlyQuote:
Did you experience some positive results with this combination ?Quote:
If so could you tell us :D :toast:
Did you program the eeprom of the shuttle with winflash ?
And my last question where did you get the K8NHA eeprom ;)
yes it's betterQuote:
from my K8NHA of course :D
I didn't reprogram this eeprom
At last someone who agrees with me 390FSB and some ppl still saying PCI is unlocked!Quote:
Well done BTW cpulloverclock!
Hello.
I'v got an option to hand-pick an A64 3200+. :toast:
Which stepping should I go on (full stepping details please)? which week?
I'm kinda confused...
- sorry for my english, i'm terribly tired. :stick:
Look for a green one.
Sofar all my CAAOC 0352XPMW went above 2,4 on air.
Important is that its somewhere during weak 0351 - 0359 those go really nice.. .and XPMW is also kinda important cause Ive seen those go really far on phase change.
My a64 3400+ went 2600 mhz on air... (XPMW) of course
You mean week 0352 i asume ;):)Quote:
ye as long as its 0352... my A64 3400+ 040 didnt go so far..
Whats the best OC for a 3200+ on TEC cooling? Was looking into getting the new ZNF3-250 and v-moddin it.
