I have had the same issue.
my stock clock temps are approx 29c idle and 49c load.. is that pretty normal?
Got mine from newegg :up: :yepp:
WTF.. i can't get my damn board to do 200 b clock!!! AM I JUST UNLUCKY OR SOMETHING...
i lowered the multi and did 200 and still no go.... even ran 1.5v through cpu just to make sure that wasnt the limiting factor
which voltage should i be upping to go with the base clock!!! would that be qpi or what!?
where do find batch number??
as for 180 b clock... yes i can do 180.. highest bootable bclock is 181
3837a769 would be my batch
i know its not the cpu... cuz i even tried 200 b clock at 1.56v and no go
cooled with an apogee gtz
That's weird most ppl are reaching 210 max block some even more.
Upped QPI/VTT?
I've gotten mine up yo 215Bclk, not sure if I will actually run it at this though. As it is now @ 200 Bclk my 1333 ram is running at about 1606 @1.34v memtest stable. Not sure It could handle running much higher then that if I bump up the Bclk further. Guess I could drop my ram down to just under or around 1300 tho. Not sure how much of a difference that would make.
Am I missing something, I seem to see some people posting multipliers of over 20x on 920/940's... Its locked at 20x isnt it? Or is the p6T deluxe just fail?
Also was wondering what people were running as far as CPU PLL v, I have mine up to almost 1.9 @ 200 Blck x20 (4ghz), vcore 1.375. Is it worth upping CPU PLL further to get more stable @ lower vcores? Not sure what exactly is high/low for CPU PLL voltages.
More Everest results please :)
QPI/VTT at 1.9V is suicide for 24/7! :eek:
Up to 1.65V should be relatively safe (as safe as ocing can be ;) ), but 2V kill an i7 - not to say - instantly, but quite fast. That's was saaya was telling in one of the threads concerning voltages.
Yea sry about that, I definatly meant CPU PLL voltage :D
Really not sure how much the pll voltage effects everything.
Anyway just screwed with it a bit, Can post @ 215 Bclk (No windows)
Windows @ 213 (low Multi High vcore)
http://img399.imageshack.us/img399/4...3x15nz3.th.jpg
Windows @ 210 (20x multi)
http://img399.imageshack.us/img399/3...0x20dx9.th.jpg
Anything over 1.4 vcore is a bit high for me, I guess Ill have to see what I can get running stable:yepp:
These chips dont seem half bad so far, at under $300 the 920 seems great, glad I didnt shell out extra for 940/extreme.
Odd how different some of these chips are fairing so far, im really surprised some people are stuck at 180 bclk :(
Ill throw up some benchies once I get something fairly stable
When ya'll say 'i can reach this bclock' etc, are you talking about 100% stable bclocks or just benchable bclocks or just bootable bclocks?
Max i've booted is 222 but i had to drop to 213 for 100% stability, with 1.44v QPI.
Ummmm yeah i wouldn't run that high QPI :eek:
I don't want to go near 1.5v myself, though really some knowledgeable people are saying 1.65v is fine... But i mean if only 1.4-1.44v can get me 213 i think i'll just take it and be happy :)
Jumped from my 187x23 to 192x23 - Windows wouldn't even load :D So i dropped one at a time and i'm currently @ 189 bclk which is looking to be my max stable with 23x multi. Any higher cpu mhz and i will need to go over 1.5v which i just will not do. This gets me 4.35ghz~ though and 9.6s~ SP 1m which is not bad, and still loaded at 59c (HT off) I still think i'll end up dropping to 1.3-1.33v and sticking with the 4.1ghz for 24/7.
