Here's my 24/7 setting with Team Xtreem 2GB DDR-1066 (D9GMH).,and some everest benching.,is it ok?or i missing something here..
New results folks. 10k bandwidth cracked across the board :toast:
E8600 stock cooling
4X1Go Vdim 2.35 volt
http://just.dod.it.free.fr/E8600/screen029.jpg
cellshock pc8000 C4
http://img56.imageshack.us/img56/8746/654ts3.jpg
Blimey... never thought this thread would keep growing an growing like it does, its almost as big as the P5Q mBIOS thread :eek:
Beyond 4Ghz barrier.,but not very impressive..
You should be able to run a lower PL, TRFC is loose too.
An update for the 4.23Ghz with PL8 and 10k read score..:up:
My 535x7.5 result..quite happy with it..
Nice results there:D My sh...y P5Q non pro looks like she doesnt like D9GMH. I have pair of Crucial Value 667 CL5 2x1GB(D9GMH), and they cant go more then 1100 on this mobo.With SuperTalent ddr2 800( PowerChip i can hit 600FSB(1200ddr2) easy). Any experiences with P5Q non pro??
Sry for my bad english:D
nice one ezaleina,great memeory results you got there.
http://i48.photobucket.com/albums/f2...6/everyday.jpg
every day settings. 2.19v (ram is rated to 2.2)
d9gmh crucial lanfest aka NEWEGG RAM. rated for pc6400 :p
1200 5-5-5-5
hows some 11k across the board?
http://i48.photobucket.com/albums/f2...76/occrazy.jpg
shall i go higher? im still at 2.19v
Been playing with ddr3 recently, had to make the switch, got me a striker 2 extreme, pretty sweet board, great bandwidth and latency on this board:up: I do miss my xtreme team 1300s.
I haven't YET been able to get the heatspreaders off my Cell Shocks (1000MHz CL5 kit) so I don't know if they are GKX or GMH, but they are absolutely :up:. Did some quick benches with 2.2v (I will go no higher for the moment) and surprisingly I see a drop in SPI performance going from 4GB CL5 to 2GB CL4. :shrug:
DDR 950 4-3-3-8 2T 2.2v
http://i293.photobucket.com/albums/m...9hn4_3_3_8.png
FINALLY! You guys will have seen this many times before but this is the first time I've ever managed sub 10s 1M, and it's all thanks to Micron D9. :D Tightened tRC and tRFC just a tad and went from 10.1s to what you see below. Needed 1.5v in BIOS for the CPU so won't be doing that again in a hurry lol. :yepp:
4.7GHz (495x9.5) DDR 990 4-4-4-8-2T
http://i293.photobucket.com/albums/m...5x9nhSUB10.png
Nice clocks you got there, guys :up:
11k Read is nice !
I now have confirmation of which ICs my memory uses :D
http://i293.photobucket.com/albums/m...nnyRhys/HS.jpg
http://i293.photobucket.com/albums/m...nnyRhys/IC.jpg
cellshock PC8000 C5:
http://img406.imageshack.us/img406/5...5650zx9.th.jpg
teamgroup pc9600:
http://img518.imageshack.us/img518/8...clubty3.th.jpg
1300MHz C5 at stock volts :eek: very nice
I'm not going near 2.3v on this mobo so I'm trying to get the best I can with 2.1v. The GKXs seem to love CL4...just did an hour of prime at 906MHz 4-3-3-10 2T with 2.1v, going to try the same again with 4-3-3-8. :up:
Hey lenny, how did you get those spreaders off? I have the proper screwdriver to get those weird screws out but on each spreader 2 of the screws seem to be jammed in an my special 'driver just chews the heads up :shrug:
Yeah the screws are not easy to work with. You need to push down pretty hard to make sure the head of the screwdriver engages with the screws - it took me a while to actually get the screws turning. I thought I had the wrong size fitment at first, but it just needed a little more encouragement :D
