Hey nice setup you did there how does the 200mm fan for your radiator located on the top ?
you have a 120X2 as radiator so does it keep kool? your 200mm cover 2/3 of the rad is it anuff air flow ?
Hey Since you build your self a LC system can you tell me if i can run the radiator upside down once it's filled & sealed ?
anyway MAAjA amazing rig you build there Premium Parts !!!!!!!!
http://www.xtremesystems.org/forums/...postcount=1049
i choose the vertical position for the rad & use the fans in front of the Antec to ventilate the 220 Rad
http://i173.photobucket.com/albums/w...007/rad2-1.jpg
