well i hit a wall and i'm sad :( anything after 395 is fail...
Does anyone know when will the .13 bios become final ?
Thanks George,wil try that too,as for the chipset,I have already checked it.AS5 had perfect contact.Also tried Ceramique,same resaults.I beleave its just a mater of my chipset.Quote:
Originally Posted by hipro5
Just to inform you that I also had problem with the bios battery.When I was cutting the power,everything in mGURU menu was reseted at stock.The weard is that it had only to do with mGURU menu.Everything else(time/date/raid/boot sequence ect)was ok.When mesured the battery,the reading was 3.07v and the new battery that solved the problem was at 3.29v.The last ABIT that I had(AN7 :p: )had also problem with its battery:slapass:
Originally Posted by Hazzan
There's no secret......Only the mod for the Northbridge - a wire soldered on the back of the mobo - , some capacitors here and there, AND a heatsink on the Northbridge chipset - Swiftech with a Delta fan 4 x 4 cm 10000 rpms.......:)Quote:
Originally Posted by SLi_dog
http://www.thelab.gr/images/Hipro5/A...r_benching.jpg
The question is... where the hell are those pots going too ? :D
Nice job as always hipro...
cheers m8 ;)
Any subzero screens ;) ?
:DQuote:
Originally Posted by VoRtAn_MaDgE
If you mean with LN2, not yet....soon....;)
I cant find this board anywhere!!! :(
Got my cpu to 3.9ghz,but not stable.
http://valid.x86-secret.com/show_oc.php?id=130748
Love this motherboard :)
Originally Posted by clone38
Keep trying this board will do 3.9 stable:) , I am working on 4ghz stable now. Nice memory BTW.
Is there a way to flash the bios using a flash drive? or do i have to use a floppy?
hehe i was not meaning...so cold, but what the hell, this is xtremesystems :DQuote:
I am waiting for my mach2 modded, new gas, new evap and others mods and i wanna see some oc on the aw9d cuzz i have a p5w64ws (already modded) in my 6700.
Just wanna know the best of the best to put my little boy under ice...
That's why i need to know where the pot's are going to connect on the mobo pcb... ;)
Maybe i'll get one to myself and then test both to see wich one to keep :)
cheers m8 :toast:
Abit flashmenu, should be on your motherboard cd.Quote:
Originally Posted by sedka
i see some tricks there, there and there:DQuote:
Guys using beta 13: As we know, TRFC RAM setting came with version 13. Given that you haven't already tried it, please try if a TRFC value >40 improves your FSB OC.
Can anyone help me? My CPU does 3,82 GHz stable but with orthos blend the test failed after 39 seconds.
I increased Vmch and Vdimm and weaked the ram timings, nothing happened.
http://www.feddern.org/florian/Intel/3,82GHzC2D.JPG
Bios is 1.3 beta. Can anyone tell me how your guys get the mobo working with orthos blend?
can someone post a link to the beta 1.3 bios please?
i know it's somewhere in this thread...
Here you go.Quote:
Originally Posted by Sicness
thanks. do i need to rename the m6606c_12.b03 file to have a .bin extension? or will it flash as is?
it will flash as is
Oh is that why my oveclock wasnt the same. With 1.2 my TRFC was 28 and stable @ 400fsb. If i do 40 and above i can get more of an overclock?Quote:
Good bios got my x6800 up to 3.9ghz :)
Last time ago, I try with Bios Beta 13 no mod all with stock Fan
http://img.techpowerup.org/061018/ok1.jpg
Which the difference enters Thermal Monitor 1 and Thermal Monitor 2? This in the menu CPU Feauture.
Which to use?
Hazzan vmch for that fsb was...?
i will have a aw9d for the weekend to compare with my p5w64 ws...
Vmch 1,95volt set in bios with fan 3000rpm in chipset, vdim 2.2volt Vcore 1.575. next time I wil try with some mod Vmch. I hope get higher FSB 460 :) :) :) :) :)
