You can let
CPU TM
Vanderpool
Exexcute disable bit
ENABLED!!!!!!!!
Only disable C1E and EIST, these are not recommended when overclocking.
You can let
CPU TM
Vanderpool
ENABLED!!!!!!!!
make sure you get the thicker kind of double stickem tape...it is like a 1/16 or 1/8 inch thick...i believe "3M" makes it.
Originally Posted by Moonraker™
yes it isQuote:
Originally Posted by swiftex
@Revv23
I'll try it, thanks :)
someone sent it to me ;)Quote:
Originally Posted by pocket.demon
sorry, I meant to sayQuote:
Originally Posted by Shootist
ICH - auto
SB - 1 setting below max
well, still noothing is working :DQuote:
Originally Posted by metalazzo
I prefer to smile about it instead of crying :rolleyes:
I emailed asus France and they said that there were not aware of this problem (PEG @1X)
they're going to ask asus taiwan...
whew!:woot:
got my replacement Mobo, and all is well (so far...knock on wood)....step by step trying to get back at my 3.31 OC....first step: 3.255
THANK YOU LAWD!
ps- one quick question: any ideas why the MB temps are 2-3C higher? I was usually at 39C/43C idle/load, but now it is 42C/45C idle/load :confused:
P5B XMS TWIN Corsair DDR2-800c4 issue...
I cannot get my board to recognize all 4 one gig sticks (in POST).
no matter where I put them.
each tests fine alone in slot3 like ASUS tech told me to do.
He also told me to clear cmos. I did.
Reset the needed values.
I set the memory to 2.1v and DDR2-800 in bios
Any hints or help?
much appreciated. thanks
P.S. Where do I set the 4-4-4-12 stuff in the BIOS?
______________________________________________
P5Bdlx wifi/ap bios0711
2 packs of Corsair TWIN MATCHED XMS ddr2800C4 ram
Antec TPII-550
Armor case
1.4Tb of SATA2 across 5 drives
2 DVD burners
X-fi plat (not installed yet)
Viewsonic VP2030b
5 HID units
WinXPpro Sp2 + updates/fixes
this amazes me!...i am surprised the Asus tech person didn't direct you to page 2-14 in the manual...it says:
if you install four 1 gig sticks, the system may detect less than 3 GB of total memory because of address space allocation....
Originally Posted by ssabripo
Heatsink mount. Remount it and see if it lowers.
heatsink affects MB temps???:confused: First I've ever heard of that...:wth:Quote:
Originally Posted by NO1B4ME
He means the NorthBridge HeatSink.
Mel
if you are getting 43C(!) for MB temperatures on load, i think you don't have enough cooling for your board and, more importantly, the NB. i'm guessing that you are not using the stock HS, which pushes air around the NB, and you do not have a fan blowing at the NB and/or SB?Quote:
43C is nothing.
That's perfectly normal and nothing to worry about.
actually is your avatar pic a quick shot from one of the members of the asus support stuff reading your posts ? :banana:
I get 32°c MOBO temp on load in games (more important for me!) and benching. thats the highest it ever gets. Full stop.
no, I dont...Quote:
Originally Posted by noobee
but I didn't before my board went bad either, and the temps were 1-2C cooler :confused:
my board went bad with insufficient cooling. was using the ultra 120 and no additional cooling for the NB. at your overclock rates and overvolt settings, might be important to cool at least the NB down also.Quote:
i believe asus probe trips a warning when MB temp >= 45deg? although the MB temp sensor is not really at the NB and the NB can take > 45deg, a high MB temp may also indicate a high NB temp, especially if you are not cooling the NB specifically.
[edit: added "sensor"]
for MB temp? i think asus probe sets the default threshold for MB temp at 45 deg to flag a warning. do you think it is too conservative?Quote:
Originally Posted by Falkentyne
i had a similiar situation once, high (45deg) MB (and presumably high NB) temps due to bad MB cooling. board first started hanging intermittently, then later died.
Exactly!Quote:
Originally Posted by Ace-a-Rue
It's a limitation of using a 32b OS, which doesn't allow enough memory addressing to handle a full 4GB.
Any 64b OS, including M$ Windows variants, will surpass the "3GB" intalled memory limitaion by orders of magnitude.
~ Strat ~
I would think long & hard before disabling the CPU/TM function.Quote:
Originally Posted by tommy-armour
JMO.
This BIOS option definitely disables TM1 thermal throttling, tho I'm not sure if it can also disable TM2 funtions.
By disabling TM1 you're allowing ur proc to exceeed the Intel thermal specs, w/o having the ability to maintain spec using TM1 throttling. The results, under the right (or more accurately, wrong, if you care to see it that way) conditions, can have a disasterous effect on ur proc.
I learned this the hard way when I was running air coolied Distributed Computing 24/7, & my window airconditioner went out during the summer. I stupidly disabled the TM in order to run at full production, even tho my cpu was bouncing off the thermal threshold, & was throttling.
Within three weeks, the damage was done. The chip, a 640 'NO', which had been an excellent OC'er, lost it's ability to OC, for the most part, & even required Vcore exceeding stock specs, just to run stably at stock clocking!
I could see disabling it for a suicide run, but if you think you may be running at throttling or near throttling temps, regularly, then you may want to reconsider disabling this function.
Of course, if ur not running near throttling temps, there's no need to disable this function! ;)
FWIW
~ Strat ~
hmm, some raid help please:
I've installed windows on a single 320 gig sata drive.
Before install, I changed the bios to raid and added during install with F6 the intel raid storage driver. Now I've installed everything and added the second 320gig to my config. First is on a red connector, the second on a black.
I'm now looking at the intel matrix storage manager bios screen, but can't figure out how to setup raid1(mirror) and use 1 as template for the other.
I'm afraid when I try it, the one with the windows install is lost.
1. dont connect the other drive to the black connector....both go on reds.Quote:
Originally Posted by eyes.only
2. did you create a RAID volume? during POST, press < ctrl+i > and it will take you to the intel matrix RAID volume screen...there you need to create a raid array of your choice (raid0, raid1, etc).
however, having said all that, I'm not quite sure how to tell Windows to copy the contents of the one drive over the other for the RAID1 setup....I thought I read somewhere that once you install windows in a non-RAID configuration, you cant go to raid....but I could be wrong. :confused:
Well just tried my luck inside windows with the intel matrix console.Quote:
There was an option with something about raid1.
So now it's doing somekind of migration which will take 1hour and 47 minutes.
So i'm keeping my fingers crossed.
And I've still got one on the red connector and one on a black.
That's what the manual says that the black one is for data disks and the red ones for boot.
right, but that's a different scenario.Quote:
RAID1 basically has a mirror from one drive to the other, and thus both need to be connected on the red (see manual). The black ones are for slave drives i believe.
everyone I know who is running these mobos in RAID1 has them both on Red, including myself (RAID1, 2x250 SATAII)
:confused:
