omg:rolleyes:,you must test the newest nanoxia fluid!!!seems to be very good;)
the glow effect under uv is very nice so far...the whole test with all fluids will take some month :)
http://www.abload.de/img/img_377136u.jpg
That is the nicest green I have seen. Is that available in the states?
i think only in europe until now, you may ask their support for more infos...
http://www.nanoxia.net/index.php?opt...emid=5&lang=en
HOLY :banana::banana::banana::banana::banana:, Thats so.. green! looks amazing! what about the price?
Feser One is the best one.
Feser Acid Green looks nearly the same and...as you know...itīs available in the US :)
http://www.abload.de/img/img_4117iix.jpg
Doesn't look the same to me...maybe the plastic of the bottle is tricking my eye.
i made a little test - out of the bottles :) the difference is bigger under UV as with normal light:
http://www.abload.de/img/img_4122vc7.jpg
http://www.abload.de/img/img_4126lwg.jpg
the Nanoxia Iceglow looks nicer under UV.
yeah, it looks greener... however weird that might sound
You can't say that for sure untill it's tested :) It could be possible that Nanoxia is better but that "in the worst situation" it destroys all your block by leaving a green filter on you acrylic tops.
That's a very extreme example but you will only know when a coolant is better then the otherone when you've tested it yourself for a longer periode of time.
The Nanoxia looks to be a bit more opaque under UV.
what about dirty in tubes or reservoirs?
I think we are offtopic.. there's a topic feser vs nanoxia additives?
how do all those compare to distilled water? ... are they better? or do they just look cooler?
Look cooler, Distilled for practicality, UV Reactive for bling, UV Tubing for the best of both :)
In my previous LC i used Feser One Acid green, i think the rig was green enough.:D
Attachment 85246
Attachment 85247
absinth :D
Hi! Been using these forums for a while now, thought about time I uploaded some pics. Camera's not great so not up to the quality of what others have been puting up:
http://img222.imageshack.us/img222/8251/newpcbu5.jpg
By nuckinfutz, shot with EX-Z30 at 2008-09-15
http://img222.imageshack.us/img222/7016/newpc6og0.jpg
http://img231.imageshack.us/img231/6044/newpc13os1.jpg
http://img222.imageshack.us/img222/7024/newpc8si6.jpg
Hi to all, im new here, can you recommend what mosfet block i can use on my MSI p45 platinum mobo, thank you.
I gave link so that something to measure can he fits;)
http://www.aquatuning.de/index.php/c...Watercool.html
