took a few hours with slow progress, until I tilted the case in various directions which helped a lot getting the air out of the rad within a few minutes, then it wasnt much longer until there was no air left.
Seba that looks great. Are those 1/2" ID 3/4" tubes?
I'm really liking the compression fittings.
same product but different in sizes
he used 3/8x1/2 Bitspower compression fitting (AFAIK)
and you link a 1/2x3/4 Bitspower compression fitting
http://i192.photobucket.com/albums/z...p/2840cdf6.jpg
http://i192.photobucket.com/albums/z...p/914f8525.jpg
I have this:
http://www.frozencpu.com/products/22...n_Fitting.html
you thought about these
http://www.frozencpu.com/products/80...tl=g30c101s178
these do not fit on blocks EK NB & SB
http://img98.imageshack.us/img98/467...omplettru0.jpg
http://img529.imageshack.us/img529/2...closeupxo3.jpg
http://img373.imageshack.us/img373/7...ttseitema8.jpg
http://img49.imageshack.us/img49/764...0cfobensp0.jpg
http://img364.imageshack.us/img364/1...cfuntencg6.jpg
http://img356.imageshack.us/img356/7...tekobennf0.jpg
http://www.gravedigga.de/gravedigga/...preme_oben.jpg
http://www.gravedigga.de/gravedigga/...reme_unten.jpg
Built this, one year ago :) But the it will strangely never be finished :( allways gotta do sumthing with it :p:
http://www.bandwidth.se/thumbs/10225.jpg
http://www.bandwidth.se/thumbs/10224.jpg
I kinda like tygoon, after a year with normal battery water (changed every 3rd month )and that i recently put in green glycol it kinda looks like sewer water :D i allso digg the towel :) used as vibrationdamper cos my ''hdd rack'' wont fit with my 3870x2
mmm loooking good
Your card is bending a lot near the ram slots. Just like mine. And just like me, you have an EK fullcover block on the hd4870
seba84_2005, what is the fan in the back?
funkflix, Is that stock nb cooler? looks weird.
wow some amazing setups here, I haven't posted in awhile but I just finished mine, I'm too lazy to get it as clean as some on here but oh well
http://img353.imageshack.us/img353/3987/comp1al5.jpg
http://img353.imageshack.us/img353/9963/comp3vp6.jpg
http://img529.imageshack.us/img529/5078/comp2hv5.jpg
http://img353.imageshack.us/img353/8924/comp4bw2.jpg
http://img353.imageshack.us/img353/c...pg/1/w1037.png
|Oc|REvO_HsArC sweet-looking setup there!
New case, I've bought the Lian-Li PC-A70B because this case will allow me to put 3 rads in :D
I had a Lian-Li PC-71 before this :)
Hope you like it, any questions?
Just ask :up:
PS I used old/broken fans as shrouds, ripped the guts out and then used the "outside", works like a charm :)
heres mine first time i ever watercooled.
Finally,my beast:)
http://www.pctunerup.com/up/results/...8_DSC00504.JPGhttp://www.pctunerup.com/up/results/...2_DSC00505.JPG
http://www.pctunerup.com/up/results/...0_DSC00507.JPGhttp://www.pctunerup.com/up/results/...0_DSC00508.JPG
http://www.pctunerup.com/up/results/...5_DSC00510.JPGhttp://www.pctunerup.com/up/results/...9_DSC00513.JPG
http://www.pctunerup.com/up/results/...2_DSC00514.JPGhttp://www.pctunerup.com/up/results/...7_DSC00515.JPG
http://www.pctunerup.com/up/results/...8_DSC00516.JPGhttp://www.pctunerup.com/up/results/...6_DSC00519.JPG
http://www.pctunerup.com/up/results/...1_DSC00522.JPGhttp://www.pctunerup.com/up/results/...8_DSC00523.JPG
http://www.pctunerup.com/up/results/...5_DSC00525.JPGhttp://www.pctunerup.com/up/results/...7_DSC00538.JPG
http://www.pctunerup.com/up/results/...0_DSC00539.JPGhttp://www.pctunerup.com/up/results/...2_DSC00540.JPG
http://www.pctunerup.com/up/results/...7_DSC00541.JPGhttp://www.pctunerup.com/up/results/...0_DSC00542.JPG
http://www.pctunerup.com/up/results/...1_DSC00543.JPGhttp://www.pctunerup.com/up/results/...6_DSC00545.JPG
http://www.pctunerup.com/up/results/...1_DSC00546.JPG
Complete WORKLOG here --> MM U2-UFO Duality dual loop
I tired slim the bitspower compression fittings for tygon 1/2 tubing will NOT fit the D-TEK fusion. They also will not work on the EK NB/SB max or the EK NB/SB ASUS 1.
They do however work on the mosfets for the 790i EK-Mosfet ASUS 3a.
Go for Bitspower single water block solution for cooling the NB and SB in one shot, should be out soon. The holes are far apart 1/2 compression fittings look like they should fit no problem. This block will not inhibit 3X SLI if it's in your plans...looks killer too.
Hey trigger, thanks a lot for that info! I really needed that :up:
So I guess out of the 8 fittings I already have, I can use 4 at least :)
I say 4 because 2 for the D-tek V2 and 2 for the BT Black Freezer since in this picture, the holes look very close together :( I dont think compression fittings would fit in the Black Freezer
http://img355.imageshack.us/my.php?i...00x3003et4.jpg
One question real quick
Will I have any kind of problem (flow, restrictions) if I use compression fittings on the Rad, pump and Res and standard fittings on the CPU and NB blocks?
Also, does the D-tek GPU V2 support 1/2 compression fittings?
http://i183.photobucket.com/albums/x...h_P9090305.jpg
http://i183.photobucket.com/albums/x...h_P9090306.jpg
http://i183.photobucket.com/albums/x...h_P9090307.jpg
First WC build. It's not nearly done yet, still have to get my new GTX 280 and waterblock in, and this cheap hardware store vinyl tubing is getting replaced with some Primochill LRT 3/4" OD stuff. The PA120.1 is getting added to the loop when I get the GPU and GPU waterblock, same as the tee and fillport (which will be used as a drain line most likely, I like the Micro-res for bleeding). The rat's nest of wires is also getting cleaned up. For now it's just so the system is usable for school.
Clamps will be added when the build is up for reals, for the time being I'm ok with it like that, no leaks so far.
Silverstone TJ09-BW
Asus P5Q-Deluxe
Core 2 Quad Q6700 (lapped)
2 x 2GB Mushkin Redline PC2-8000
eVGA GTX 260 (soon to be replaced by a GTX 280)
2 74GB Raptor ADFDs in RAID0 for Vista x64 and programs (Well, one is an OEM 80GB meant for Dell, but that's not really important)
250GB WD Caviar 16MB
500GB Samsung SpinPoint 16MB
Creative Labs X-Fi XtremeMusic
OCZ 800w EliteXStream
And for the watercooling gear:
Enzotech Sapphire
D-tek Fuzion GF2 + 260/280 Uni-sink
Swiftech MCP355 with an XSPC DDC acrylic top
XSPC RS360 3 x 120mm radiator
Thermochill PA120.1 120mm radiator
Swiftech Micro-res
Bitspower 1/2" high-flow barbs
Bitspower acrylic T-fitting
Danger Den delrin fillport
Primochill 1/2" ID 3/4" OD LRT tubing, black
Primochill anti-kink coils, UV green
Distilled water + PT_nuke
My flow is fine with the mix and match between 1/2 compression and regular 1/2 barbs. Note I got the compression fittings on my rad(sig) and I got them on the RES using some of the funky koolance fittings. Swivel 90 and swivel 45
see pic. No idea about the D-TEK GPU sorry.
