I love the tubing...Sweet
Great photos great designs. Well done m8:up:
Case: Lian Li PC-G7
Pump: Laing DDC3.1
CPU: D-Tek Fuzion with Pro Mount & washer
NB: EK Water Blocks NB/SB 5
VGA: AquaXtreme MP-1 GFX
Hose: Masterkleer 7/16"
Fitings: EK HighFlow Fitings 1/2"
Radiator: XSPC RS240 with 4x Yate Loon D12SL-12 @ push-pull & XSPC RS120 with Sharkoon SE1000
Fan controller: Zalman ZM-MFC1 Plus
Reservoir: XSPC reservoir top
http://i399.photobucket.com/albums/p...f/IMG_1462.jpg
http://i399.photobucket.com/albums/p...f/IMG_1503.jpg
http://i399.photobucket.com/albums/p...f/IMG_1485.jpg http://i399.photobucket.com/albums/p...f/IMG_1486.jpg
http://i399.photobucket.com/albums/p...f/IMG_1483.jpg http://i399.photobucket.com/albums/p...f/IMG_1482.jpg
http://i399.photobucket.com/albums/p...f/IMG_1481.jpg http://i399.photobucket.com/albums/p...f/IMG_1506.jpg
http://i399.photobucket.com/albums/p...f/IMG_1517.jpg http://i399.photobucket.com/albums/p...f/IMG_1528.jpg
http://i399.photobucket.com/albums/p...f/IMG_1479.jpg
http://i399.photobucket.com/albums/p...f/IMG_1499.jpg
aspms* may I know what coolant you are using?
The Nickelgang :D
http://www.abload.de/img/img_3885nni.jpg
I have one Sharkoon Silent Eagle 1000 in front blowing straight on pump so no worries about heat! ;) And I have made similar wc loops for my friends with exact the same insulation for pump and there are no problems at all- one of those pumps is currently running for more than a year now! :yepp: And it
absorbs all the noises and vibrations very well! :up:
I don't know original manufacturer- it came with aquatuning.de label but AFAIK they don't produce stuff like that by themselves! It's listed here: http://www.aquatuning.de/product_inf...LLOW-50ml.html
Actually in real life this coolant and my whole rig looks more dark and better in my opinion than in my photos, I just cant set right settings for my camera to make good photos! :p:
Hey guys
I put the 8800GTX in the loop, the Q6600 temps where not hurt at all and the 8800GTX with 1,5vgpu went up stable 3dmark06 loops and vantage at 702 /1836/1053...at 47C IDLE / 54C LOAD with 23C ambient, i had 52C IDLE / 69C stock clocks (575/1350/1800) with air stock cooled :)
here are some pics
http://s2.subirimagenes.com/otros/pr...9p10101711.jpg
http://s2.subirimagenes.com/otros/pr...4p10101551.jpg
http://s2.subirimagenes.com/otros/pr...2p10101541.jpg
http://s2.subirimagenes.com/otros/pr...7p10101561.jpg
http://s2.subirimagenes.com/otros/pr...0p10101151.jpg
Just redid mine with PA120.3 (from PA120.2) and GTX 260. Holes are cut underneath the PA120.3. Using medium speed yates in pull. Went with Pentosin G11 this time, blue over the HydrX green.
Specs:
Q6600 G0 L745A @ 3.825Ghz (1.45v actual)
Asus P5K-E/WiFi Pencil modded vdroop (Bios rev. 1102)
G.Skill PC2-8800 DDR2-1100 4096MB Memory
1/2" ID Masterkleer tubing, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Thermaltake ToughPower 1000watt PSU
PNY GTX 260 756 core /1242 memory /1566 Shader
X-Mystique 5.1 Digital Dolby Sound Card
Acer X222Wbd 22" LCD
WD 640GB WD6400AAKS HD
http://img149.imageshack.us/img149/4...0979oi4.th.jpghttp://img149.imageshack.us/img149/3...0984bp9.th.jpghttp://img214.imageshack.us/img214/6...0985on5.th.jpg
http://img255.imageshack.us/img255/2...9323ca6.th.jpg
http://img214.imageshack.us/img214/1...coreak2.th.jpg
Looking good Andres Sergio!
Just some prelimenary shots of the new rig. Only just got it up & running and I still need lighting and fan control at the front but it's turned out OK.
http://i9.photobucket.com/albums/a96...666/Comp-3.jpg
http://i9.photobucket.com/albums/a96...666/Comp-4.jpg
http://i9.photobucket.com/albums/a96...666/Comp-2.jpg
http://i9.photobucket.com/albums/a96...im666/Comp.jpg
The fans at the front are custom UV LED Zalmans, I swapped the stock red LED's out. Switch on the left is power switch + power LED, switch on the right is reset switch + HDD activity LED.
Great custom case!! - looks fantastic!
What sort of temps are you seeing with the EK 4870x2 block??
Ummm can I have it :D
kthnx <3
24C IDLE at the moment
31C LOAD last night according to CCC
Not bad considering the pump is on 2 (of 5) and I'm cooling CPU & Chipset as well.. CPU @ 4.05GHz 1.3V
My only regret is that the EK product page for the block says fittings included, I selected 1/2" from the drop-down menu when I ordered but none arrived. Eddy tells me they added it to the site without fittings (but I managed to select them when ordering?!) so he basically says too bad so sad, unfortunately the last EK product I can purchase from a moral perspective if they have that attitude.
Hmmm if the price were right perhaps :yepp: but probably impractical, it is a very big case.
I was saying it in jest :p:.
some very nice stuff! :up:
OT: can anyone verify that the ek 4870 blocks are single slot?
These look just like my HD3870X2 blocks and I am able to use the slots beside the cards if that is what you mean. For instance I have a Soundcard in a PCI slot directly beside the graphics card on the acylic (thickest) side.
Heres my LC rev1 , hope you like it ;)
http://img519.imageshack.us/img519/2937/06gi5.jpg
http://img519.imageshack.us/img519/8926/07iv1.jpg
http://img519.imageshack.us/img519/386/08kt2.jpg
nice TJ07 - show us more!
