nice scores with that 7900gt.
thnks guys :D
Btw: new 3dmark 2005 score :
Opty 165@2700mhz || XFX 7900GT @ 670/870 @ 1.40Vmod
http://img452.imageshack.us/img452/3802/2k59uq.jpg
regards
Ill Add mine . Galaxy 7900GT 1.4 Volts so far and still climbing
http://teknetixx.com/mypc/7900gt/3d052.jpg
i have:
Asus 7900GT default 450/1350(i think)
Stock Volts
oc'ed to 550/900
riva tuner will not even let me monitor temps. i thought default speeds were 450 and 1350... but when i open the nvidia part with coolbits, it only lets me take the memory up to 900mhz max and core speed of about 560 stable. however, the asus utility lets me go to 550 core and 1550 ram speeds. why doesnt riva tuner or the nvidia program work? and how do i add volts? is it a soldering process?
umm..that's programatical reporting differene. 550 core is normal for gt's and 900 mem in coolbits is often stated as 1800mhz elsewhere
you'll probably find that coolbits reports half the asus utilities memory speed at stock.
all you need now is better cooling and a like 1.4vgpu voltmod :D
i have a nv6 silencer on it.Quote:
Originally Posted by flytek
so the 900mhz is really 1800mhz since its ddr? where can i find instructions on this voltmod:D as long as its not too terribly hard, ill pick up a new solder tip and try it out.
New Score :)
how are all you guys getting more memory headroom with nvidia/coolbits tuner? particularly, the screen above where it says performance profiles... how do i get to that screen or is it a different program, if so which one?
XFX 7900gt EE (550MHz core and 1630MHz memory stock)
This is with a 1.4V mod and a NV Silencer 5 cooler
Temps are not the greatest (~50C idle and up to 85C load) I've seen 90c on a hot day!
http://img.photobucket.com/albums/v2...rk05score3.jpg
__________________
DFI LanpartyUT nF4 Ultra-D (704-2bta BIOS)
AMD Opteron 146 (CABYE 0540 FPMW)
Big Typhoon
2GB Mushkin eXtreme PC4000 (Black)
Nvidia XFX 7900GT EE
WD Raptor 74gb
BenQ DW1650 DVD writer
Fortron AX-500 Bluestorm PSU
NZXT Lexa case
Razer Diamondback Plasma Mouse
They are soem pretty warm temps these , mine peaks at around 55 and idles at 41 with 1.5 volts, Im using Thermalright V1 Ultra :)
Those temps only pop up during COD2. Even after 2 hours of 3dmark05 on a loop the temps did not break 75C.
thats still pretty high. i max out at 55 on my 7900GTX.
Thats an amazingly high score for a sub $500AU card :toast: :toast:Quote:
Originally Posted by Kenetixx
With my Fusion GPU block I never get above ~ 43C :fact: :eek: :D
nice clocks.. I have two of these at home waiting for the mod... and a conductive pen burning a hole in my desk. :D I should be home in a week, yayQuote:
Originally Posted by tranceaddict
can anyone answer this? please?Quote:
Originally Posted by viper650
I use Powerstrip to overclock not nvidia coolbits
ok cool, thanks. ill check that out now.
When using Powerstrip what box do you check in clock frequency in nvidia panel, manual overclocking or no overclocking? Does it matter how that's checked when usin Powerstrip?Quote:
You dont have to touch nvidia panel when using Powerstrip just use powerstrip to adjust clocks
Is it possible to use a 6800 Ultra cooler as a cooler for my 7900GT? If its possible, do I get better temps?
im getting scores with pentium d at 3.975ghz and 7900gt at 560/815 of 5400... does this sound right? ram is at 331@4.5-5-5-15 stock is 267@ 4-4-4-12
Hi all,
I would like to know if somebody from here, has Forceware moded to activate the SLI on Aopen i975Xa-YDG
Thank you :)
Update: I fixed the temps, now the load temps are in the mid 60s. Because I used a NV Silencer 5 which is designed for the 7800s, I had to cut it to fit. Since I cut it a little too much, I extended it by making several layers of electrical tape around it. It turned out that once heated the tape expanded and almost completely blocked off the vent. I now cut all the tape off and after hours of gaming in the hottest day yet, I stayed in the mid 60s.
I finally got my new card from XFX currently testing it at 585/1820 on stock cooler and voltage.
today arrived my XFX EE 550/1630:banana:
at stock voltages 605/1800:)
http://img258.imageshack.us/img258/661/3d069co.th.jpg
