ritey will grab one 0546xpmw thenQuote:
530/1370Quote:
I beat you in 4 of the 7 test and come close in 2 more but in nature you flat kill me. That little of a video card clock does that. I have 50 more MHz. Must be some kind of trick or tweak I'm not doing.lol
got my opty 170 today
0546XPMW low batch # 0066
http://www.johnshim.com/forums/xtrem...efaultcpuz.jpg
default voltage of 1.3! :)
looks promising
did some dual superpi 1M tests at default.
2.5 ghz stable at default! :)
2.6 ghz errors out on core 1.
This is as high as my 0543TPMW would allow while staying at 1.65+-Vcore. its not my 24/7, but its the chips max...
http://i6.photobucket.com/albums/y24.../2900Final.jpg
i really really really want to get to the bottom of this on my rig too.....can you guys do some head to head comparisonsQuote:
Originally Posted by dogsx2
hey dogsx2 ........you really need to join www.i4memory.com matey (eva2000 forum btw)
http://img453.imageshack.us/img453/7...resized3lk.jpg
http://img453.imageshack.us/img453/4...resized4ft.jpg
i'll try 2700 (i think it'll be 2700@1.48/1.5v)
edit: ambiant t°c 22
I don't think they are going to tell us the secret dinos. We are the unwashed.lolQuote:
Originally Posted by dinos22
Put the 180 in on a vapo pe, it worked it a little. In the ss below the idle was
-4/5c and load doing dual 32m was 18. How do you do dual 1.4? I think I did it with my 3800 back when they first came out but I can't do it now. I don't know how much more this 180 has got, just a first date. I do think a better phase cooler would help but I'm too cheap. Don't really know if this is a good or bad oc for a 180.
http://img361.imageshack.us/img361/1...l32m1yc.th.jpg
Tried to get on your forum but they would not let me as I only have hotmail.
That's pretty good for a 180... My 180 on water does 2.7 @ 1.5v 100% stable and will do 2.8 stable at 1.7v but the temps are just a bit too high for me to consider running 24/7 until I get my new chilly1 unit in. At that point I'll be chopping this procs head off and then letting the juice flow in hopes of 3+ghz stable.
good first resultsQuote:
with SuperPI/mod1.4 you need to create 2 separate folders and extract the proggie in each folder
when you open them you need to also manually set affinity for each SPI (Task Manager)....so use Core0 for first SPI you open and Core1 for second SPI.....that way you'll know which core is weaker too :)
I'm hoping that my phase will give me 3GHz out of mine for benching AT LEAST :D
can you crank that cooler on stock settings and see how low it can idle before the cold bug kicks in
what was the stepping again on that CPU.....i think i deleted that PM
0543UPMWQuote:
There is no crank down to it, it's just an old vapo pe.:) I did lower the volts to 1.2@2400 and got it down to -10c idle. I think this 180 is part turion.
Auto/auto is 1.3v.
http://img381.imageshack.us/img381/6...21800hd.th.jpg
I've decided that it's definately time to nakify the 180. Going to bring home a nice new sharp blade with me from work tomorrow and proceed to slice her off after I walk through the door.
Hoping that it will straigten out my one buggered core giving me a nice stable 2.9ghz... /me prays that this chip will be a good candidate for the new phase.
what's your custom WC setup.......like are you running a Storm block or?Quote:
Originally Posted by FragTek
1.3/1.35 is stock vcore for dual core Opterons so you are within the range............why would u say it's a part Turion :SQuote:
How would I use this burn in process for dual core?Quote:
Originally Posted by Super Nade
Do I assign a core to the program? If so how do I do this?
Swiftech MCW6002-64Quote:
2 x DD Maze4 GPU Blocks
Maze4 Chipset Block (out of the loop till I pick up an Expert)
Thermochill HE120.3 Rad w/ 6 x Panaflo M1A's in push/pull
2 x Laing D4 pumps
Tygon all the way around
It was the best setup I could build back when I put it together without having to get on any waiting lists for a good custom block (G4/G5). I'm very content with the loop and haven't felt that it's due for upgrading yet as I'm waiting on my chilly1 U2-UFO to come in. Once that's in I'll yard the wc gear out of the current rig, toss the cpu block, hook everything else back up and continue to keep my wc's vid cards and possibly my chipset if I upgrade to an Expert during the gear swap. At 1.5v this setup keeps my DC Opty at a pretty chilly 18-19*c and under load about 39*c on a cool night with the windows open.
The IHS comes off today! Maybe I'll be able to ding 2.8 or 2.9 w/ it off (what a dreamer i am... lol). I'll take an extra stable 50mhz, lol!
2.72 ghz @ 1.45 volts
opty 170 0546XPMW from mwave
http://www.johnshim.com/anandtech/27...546opty170.jpg
very nice - that cpu is related to mine :DQuote:
Originally Posted by shimmishim
just got my new 0546 form David Graham up and running. this thing blows the socks off the 0541. been up and running about 2 hours now (had to get in some CSS this morning, highest clokc so far the grand 3ghz and crash, my best screeny is below im burning in now at 2.8 for a few hours see what we can do. all this is at 1.44 volts in bios;3x ldt;180 ram @2.8v; will be posting back. man if this thing goes 3gig stable i'll be like a pig in mud. all i need now is 2 gigs of ram that will hold a 1t clock up there.
http://www.efegs.com/someguy/pics/various/oc/0546.JPG
very nice for moment i thought you where on air/water for that 2.9ghz heh
I just got an OEM 175 from the egg CCBWE 0547TPMW will let you guys know know how it does on a modded si-97 and a nado then latter on water then latter on phase lol moving up in he world...
Dragon
Changed my waterblock to swiftech Apogee. Still need to burn some more.
I hope it helps to bring down volts. :)
so... i have a CCBWE 0530 tmpw sitting on my bed and has been waiting to be used for about 2 months, but i havent been able to due to me not having a computer. well im about a week or 2 away from getting the rest of my parts, and i was wondering, can i expect 2.7/2.8 from this on air (TT big typhoon)? What is the average speed on air of 0530 tpmw's?
thanks
Originally Posted by terrordemon
i would say YES..
OH YEA!!!!!!!?!?!!!!!!!! LETS HERE IT FOR THE 0546 DID SOEM THIGN MY 0541 NEVER DID!!!!!!!!!!!!!! HIT THE 3 GIG MARK
PIC PIC PIC
http://www.efegs.com/someguy/pics/various/oc/3gig.JPG
I just recieved my Opteron 170 0546XPMW from MWAVE, I will post results soon!
