Here a GTO i modded for a friend, cooled with Stockcooler, untweaked timings and 1,59V. Just quicktests. :)
http://213.202.211.105/gravedigga/Temp/06.jpg
http://213.202.211.105/gravedigga/Temp/8051.jpg
wow...
Sick scores, nice clocks on that card.
Originally Posted by blind_ripper
1.76v VGPU , with watercooling
VDD not modded , I bench the 2K5 with xs timming ~ 640 and 680mhz with stock timming.
http://service.futuremark.com/compare?3dm05=1775672
7725 in 3DM05 with vGPU mod. vDD and vDDQ mod to be done soon. At 669/618 MHz with CPU and GPU under water (vGPU @ 1.69v). Aiming for 8k :)
Nice scores, im debating digging out my gpu water block as the zalman dosent seem to be cutting it anymore, with 1.48v on gpu 600mhz it gets to around 70c, loaded for 15 minutes, and thats with 2 120mm fans blowing over the card one on full whack the other 7v.Quote:
Originally Posted by K.I.T.T.
Got round to doing the vddq mod and got the ram up to around 650 using 2.2v vdd and vddq.
What temps is everyone else getting with what volts and cooling?
Hmmm....thats a bit dodgy Pancake. With the stock cooler at full blast at 1.46v, I've never seen it go above 62*C....
I gave the card a clean out when i took it out to do the vddq mod, so its dust free, maybe ill try remounting it, i dont know if i can botherd messing around plumbing in a gpu block.
MI new connect3d x800gto didnt mod, has laser cut :(
solved the temp probs by the looks of it, i forgot when i had the side of my case off for about a month i turned all the fans blowing in so no hot air was getting out, back to under 60c load now
I installed new graphics wc block but for some reason at 615mhz core speed (testing with ati tool) my screen gets black.
Any suggestions?
yes, this is the limit of OC :stick:Quote:
vmod time.
Its no as high a overclock as the GTO2s out there but I just installed a ATI Silencer5 rev2 on my Connect 3D GTO that is flash to all 16 piples. It has a R423 and samsung -2.0 GDDR3 now at 570core and 545 mem with out volt mods. Its the best video card I have paid under $150 for.:)
Got this from Newegg referb line and I think there is one still there for $120 now.
EDIT
The Connect 3D GTO for $120 is gone now but there are 2 GTO2 referb for $170 and $173.
Nice price for C3D x800gto.
I install today Akasa 862 cooler on my x800GTO Fireblade@x850xtpe.
With stock cooler 610Mhz@75C, now 650Mhz@58C all@1.55Vgpu.
I will install ramsinks tomorrow, and bench with cool air.
know somebody a Vmod for a connect3d x800gto? because the pcb is diferent to the reference
pictures front and back with no heatsink would helpQuote:
Originally Posted by Umek
Im having problems with ATI Tray tools...whenever i start it, my PC doesnt respond for lke 4-5 seconds (cant move the mouse, etc). i just reformatted. It didnt happen before :stick:
not sure if i ran any 2k1 with my opty, but was bored today so gave it a quick spin http://service.futuremark.com/compare?2k1=8896000
Hmmm...Your nature score is very high compared to mine:
http://service.futuremark.com/compare?2k1=8888479
Did you use LOD or something?
best i have got out of my sapphire gto @16p 1.7v is 756/648 8869 in 05 on a fx-57not to shabby nice cards for the price
Hmm, i modded a Connect3D X800GTO, and the relvant parts are the same i think, just the volatge-reading points are different to the GTO2/X850 layout.Quote:
http://img3.imageshack.us/img3/4707/modded1zd.jpg
Are ur card different to this one?
If u need the reading points, i must wait until the owner of this card is online, i made a picture for him, with the points, but i don't have it anymore. :)
no didnt use lod, just set to performance in ati control panelQuote:
The nature looks ok for a run without LOD! I have around 310 Fps without LOD and 648/648MHz. :)
Here are the reading-points, if u need them. :)
http://img7.imageshack.us/img7/4426/messpunkte2sf.jpg
