The CMOS Reloaded is stored into the main memory...Quote:
Originally Posted by largon
So if you cannot change setting, that means the access to the memory is not ok (OC too high?)...
Normal working procedure:
Bios is loaded into memory upon boot
Changing bios setting happens in memory (different area than old settings)
pressing F10 saves them onto the bios chip
That's the reason why after pressing F10 you need a reboot,
so settings on bioschip are identical to those in memory.
Hope the explanation is a bit clear...
