good idea, just try it dude
ok the format has done little to nothing
For some bizarre reason prime was passing a few tests at the start @ 245, 250, 255 but that was only the first or second tests... After leaving it on longer they fail
Even with max vcore and 3.5v for ram it wont pass
Im about to prime at 240
The memory controllers on these amds suck.. Is it just 90nm ones or 130mm 939 aswell? I cant believe how unstable this cpu is at high mhz for the ram :(
Did i get a bad chip? I dont think so coz it can do 2600mhz prime but not in sync with ram
Just came back during lunch hour and there it was, a FedEx package waiting for me :banana:
Unfortunately, I burned my NEO2 a few days ago. My setup was at 2.8Ghz 1.8vcore and I know it was stable because I played games with it for a few hours the previous night. The next morning when I switch in on, flames shot up from one of the MOSFET between the cpu socket and the USB port! Luckily nothing else burnt. I'm now stuck with my spare board which is an Asus A8V which is not compatible with the DDR Booster :mad:
You forgot to say 17mhz more than you get on your NF2 board. :) That DFI NF3-250gb is a bad mutha.Quote:
Originally Posted by cantankerous
Is this memory any good for Intel systems? I am building a 3.0c+AI7 rig right now and not sure what memory to get.. I already have some Mushkin TCCD on the way... but then I read here that TCCD does not play well with the AI7 so I may use it in a 64 rig i will be building.. So i need to know what to get for this p4..
Theres no point get this for an intel rig.. Get some OCZ's PC4200, 4000 stuffQuote:
Originally Posted by q149
Hmmmm I guess my thoughts and hopes of a stronger, better board performing higher with same volts just may be true. I guess the DFI UT can scale higher with same volts than the NF2?Quote:
Originally Posted by andyOCZ
ok guys I found some in the UK
http://www.gladiatorcomputers.com/ac...ld_Series.html
Can somebody from OCZ take a look overhere ,i thought that it was for support on OCZ products,but nobody looks overthere,its a problem with psu 520w powerstream,thank you:).
damn fridays, so i get my ddr booster today, all excited to add some volts to these vx sticks, install the booster, look at the led readout and wait and wait, nothing, so i come online antec neopower has no -5v rail.
BAH
so i ordered up a powerstream 520, hopefully this will fix my drooping +12v also.
now its back to waiting again.
edit: i swapped out my neopower for my old trusty enermax 365p-ve which has the -5v rail, and its working, currently burning in the ram at 3.2v @ 220mhz 2-2-2-10, looping test 5 on memtest 20 times, then booting into windows like mentioned before and running superpi 2M. all is well so far
well i know for sure that the ocz powerstream is the big daddy of psu's
OMGQuote:
Originally Posted by ryanpgroovy
OCZ 1024MB EL DDR PC3200 Dual Channel Kit Gold Series Voltage eXtreme (OCZ4001024ELDCGEVX-K) £179.95
Wanna know how much is this in USD $ ? :slobber:
345$ :slobber: :slobber: :slobber: :down::down::down:
really?Quote:
Originally Posted by LilGator
http://members.cox.net/jmdandrow/old.../4ghz%2011.JPG
With that memory and their customer service (rma'd 1GB memory i told them I bought on the forums that was DOA. Furthermore, they promised me good overclocking sticks!!!) mushkin's earned my business for life.
1x512mb != 2x512mb
that was with my 1gb mushkin pc3500 black lvl2 :confused: what are you saying?Quote:
Originally Posted by Torin
edit: ahhh bah i noticed it says 512 mb i must have only had one stick in for that sho. I took that like half a year ago before I sold it for $400
Lemme see if I can find a dual channel shot
:cool:
does the pic match up with your current setup?
4ghz on an FX-55 mmmmmm:)
thats with like 17.5% VAT thoughQuote:
Originally Posted by TEDY
Life dont work like that though Tedy... you live in the UK, you earn pounds... You live in the USA you earn US Dollars.Quote:
Just to put things in perspective... we pay $500-$700 per 2x512 quality RAM in NZ and I'd say our salaries are pretty similar on average to US salaries, WITHOUT currency conversion.
computerpro3,
that is jus a screeny buddy... I have a 1x512 screeny of my OCZ VX at a VERY UNSTABLE 3.4v line... eg, under load it jumps between 3.31v-3.35v due to "low" 3.3v line sitting at 3.47v.
Even with that dubious voltage I got a higher screeny than that... I will post it in the nex day or two ;)
I just got some VX in today from the good ol' fed ex man. Popped em in at 245 2-2-2-10-1t 3.2v which is what I was running before and they are lookin good so far. Hopin I'll have some top end results either tonight or tommorow night. It sucks being a retail manager during Christmas. Not much time to play with my toy's since I am at work most of the time!;)
Alright, at 3.4v I can get 260x10 2-2-2-10-1t Not to shabby. Heard this stuff get's better as it burns in. Will see. 270+ would be ideal.
So this VX is some real good ram, hugh guy's! :toast: :banana4:
Very nice. 260 with only 3.4. That is incredible. Nice latency too. Man I can't wait to see what my sticks do when I go A64.
Nice work bud ;) Fire up those puppies.Quote:
Originally Posted by LikwidKool
When the commission checks and spiffs roll in - it's the best time of the year. Next is income tax refund check time!Quote:
seen!
