My new one. fresh off the press :)
http://i7.photobucket.com/albums/y26...c-07/pc-07.jpg
http://i7.photobucket.com/albums/y26...07-atnight.jpg
ddc ultra
tdx
maze 4 lp
2xbix
bip2
3/8th r3603
4x papst 4212ngn's on a aquaero
ddc ultra
tdx
maze 4 lp
2xbix
bip2
3/8th r3603
awesome rig dude... the neatness is superb... :toast:Quote:
Originally Posted by Sc4mpi
this was my rig.. before i went back to air...
http://i30.photobucket.com/albums/c3...l/DSC00009.jpg
http://i30.photobucket.com/albums/c3...l/DSC00010.jpg
http://i30.photobucket.com/albums/c3...l/DSC00011.jpg
was my first water setup and my first heart attack too.. while fixing this hoe up... one tube came loose and spilled coolant all over the board... thankfully nothing happened cause its wasn't powered up.. used a hairdryer to clean the mess up and everything was fine... =)
Maybe you should have bought a decent WC setup in the first place... TT Bigwater has been a no-no for a long time :nono:Quote:
Originally Posted by scream
Love those heatsinks. :)Quote:
Originally Posted by Jokester_wild
yeah.. i realised that after the lousy preformance.. my fatality is giving me similar temps.. =) if not better... :banana:Quote:
Originally Posted by D_o_S
There's a pic back in here somewherehttp://www.xtremesystems.org/forums/...&postcount=888, but yeah cut out the bottom to match PA160 fin area and put some foam weatherstripping @ hole border, then just put rad on top.
Originally Posted by MadMikeSS
>_< i would still put on the barbs, why risk it :P
here is mine, not complete by now, but it will be very soon:) :)
http://countermalucos.com.sapo.pt/corte_topo_2.jpg
http://countermalucos.com.sapo.pt/topo_corte_1.jpg
http://countermalucos.com.sapo.pt/tpo_semfita.jpg
http://countermalucos.com.sapo.pt/to...s%2Bgrelha.jpg
http://countermalucos.com.sapo.pt/tudo.jpg
http://countermalucos.com.sapo.pt/cima.jpg
http://countermalucos.com.sapo.pt/conjunto_1.jpg
http://countermalucos.com.sapo.pt/traseira.jpg
http://countermalucos.com.sapo.pt/tudo_1.jpg
http://countermalucos.com.sapo.pt/bomba.jpg
http://countermalucos.com.sapo.pt/bomba_2.jpg
http://countermalucos.com.sapo.pt/closeup_rad.jpg
http://countermalucos.com.sapo.pt/exterior.jpg
Maneliiiii,isso tá uma maravilhaaaa,por acaso podes me dar as medidas??são iguais para todos os 240,sabes?
Sick job on that top radiator mount man :toast:
I'm not liking the eheim pump or bay res though.
nao faço ideia se sao iguais pa todas.(id dont know if they are the same) pra que rad tavas a pensar?(for wich rad were you thinking?) .by the way who are you? (outro nick:D )
Yeah, that was nicely done, but it's a V1000, not hte V2000 that I have. I could probably do the same, but I need the HD racks in the bottom. It'll have to stay the wya I have it for now.Quote:
Originally Posted by mad mikee
THANKS it gave me a hell of a job to do it, but it is done=)Quote:
Originally Posted by afireinside
the bay res, and the eheim i have to keep with them because there is no money for other pump ou Res.
tomorrow i may put some pics with th WC system mounted, on cpu only, because the mcw55 will come only when money arrives:slapass:
I recently got my new tubing so it´s time for a post:D
http://img463.imageshack.us/img463/7554/imgp29298un.jpg
http://img458.imageshack.us/img458/7428/imgp29344io.jpg
http://img458.imageshack.us/img458/2620/imgp29203mz.jpg
http://img211.imageshack.us/img211/6184/imgp29233ab.jpg
http://img211.imageshack.us/img211/940/imgp29226rv.jpg
only have to fix this long tube between mobo and graphics
what do you think about it/what shall I change:confused:
PS:most of this systems here look COOOOOOOOL :slobber: :clap:
i bet that there is air inside this cooler as you used the out houle for intake:stick:Quote:
Originally Posted by funkflix
would fix that is i where you:rolleyes:
Manuel C, looking good, but you might want to get some black screws for the fan grill.
you are completely right. a friend of mine who have a pc component shop, have already those screws =).Quote:
Originally Posted by MaxxxRacer
today i have already put the DD conectors on the reservoir, and the 3/8 to 1/2 on the Rad. i am just waiting now for the Tygon tube. mcw55 will come later because money , dont grows form the floor :slapass:
Thanks Maxxx, and everyone
Another thing: the DDC gets a nice kick in performance if you use the top barb in the plexi-top as inlet. No-cost performance upgrade for you :)
Thats how i run mine. Makes top-mounted rad easier as well :)Quote:
Originally Posted by creidiki
Ill have pics up very soon, of my very first water-cooled rig.
Lian Li PC-7B / BIP2 top mount :)
thanks will fix that when my triple-rad will come onto top (inside, only have to turn the power-supply by 90 degree so it´s flat:rolleyes: )
but where to take the water-tank i can´t find any place for it (i don´t like that mounting in front of my graphics card)
PS: don´t want to have anything external as i go very often to lanpartys:(
...just use a t-line. makes it lighter as well, every little helps if youre lugging it to lans :)
How du think it is wrong? :confused:Quote:
Originally Posted by generics_user
http://www.techpowerup.com/gallery/23/7.jpg
Just as it must be ... In = In / Out = Out!
:rolleyes: lol on the other image it wasn´t clear wich hole you used:p:Quote:
with the new one everything is a bit clearer:D
PS: how many did you pay for your htf3?
I think it was about 55€. :)
