Got a new block today.
https://lh6.googleusercontent.com/_Y...0/SL740223.JPG
https://lh3.googleusercontent.com/_Y...0/SL740232.JPG
How is it you mounted the cooler, what model number, and also how well does it work?? I had to cut the out the heat pipe out and remove the NB cooler on my MSI 785GM-65 when I used my modded cooler for DreamCatcher AM3.
http://i34.photobucket.com/albums/d1...F3000N0023.jpg
An oopster as it had replaced a Biostar GXE that got a bath when the DD block that came with a BFG 280 leaked! Good catch! :up:
Oh yeah what one does not want to see in a water cooled system...........
http://i34.photobucket.com/albums/d1...v4/GPULeak.jpg
Look closely and you can see two "drops" getting ready to drop between the two middle screws! :shakes:
Looks cool, but I'd be really scared to see that :rofl:.
HD6850 watercooled :D
http://img42.imageshack.us/img42/1733/p1200036.jpg
@ jedihobbit: You just remove the original wb and then you use the Mips (http://www.aquatuning.co.uk/product_...ck-Nickel.html) wb + new screws and yes, it works very well.
http://www.abload.de/img/1cnao.jpg
http://www.abload.de/img/28nyw.jpg
Okay looks nice and good to hear it works well, however I'm being dense right now, so I'll be PM'ing you in the next day or two with more questions. Don't want to tie up the thread with my dumbness! ;)
Sooooooo many EK mem blocks!!!! Are mem coolers more for bling than function?? :shrug:
doesnt anyone have the heart to tell EK that the branding on the ram block is HUGE and UGLY?
http://www.abload.de/img/img_9794i277o.jpg
http://www.abload.de/img/img_9797y7vi.jpg
http://www.abload.de/img/img_9791l7n7.jpg
http://www.abload.de/img/img_9802w7cp.jpg
http://www.abload.de/img/img_98155702.jpg
http://www.abload.de/img/img_9811i7g2.jpg
http://www.abload.de/img/img_982417t8.jpg
http://www.abload.de/img/img_9835g7h9.jpg
http://www.abload.de/img/img_9829j73u.jpg
16/11 fittings are compatible? you've scratched a bit the black finish :(
here is mine with 13/10 fittings
http://img706.imageshack.us/img706/762/15034253.jpg
High flow !! :)
http://img156.imageshack.us/img156/6547/ekvga.jpg
yes, those 16/12mm ek fittings are compatible with both blocks. I scratched 1 fitting while testing if it fits on hk 3.0 some month ago :)
@ bundymania.....is that a "ring" flash?? :confused:
Itīs a so called UFO Led Lamp - available @ebay :)
EK RAM Dominator
http://www.abload.de/img/imgp67211frzf.jpg
