Was asking what to get the a Dual Channel (4gb) kit or Triple Channel (6gb) is there any difference for OC?
Jor3lBR
don't buy the first set i recommended....i pm'd you the right ones
check this out guys
thanks to eva..i think he did this..
http://ramlist.i4memory.com/ddr3/
Posted some multi card results.... no AM3 yet and CPU still only at 4.64ghz...
To get over this bclk wall I guess I'll need the Classi board.....
It'll be coming in either late this week or early next... :up:
I have a little GPU for hardware boints, maybe I can bench it tomorrow and get over 350... :)
This one will do? http://www.kingpincooling.com/NB-1/
yeah, that will do, thats perfect coz i think its got a probe hole already.
prolly around -40C <-> -190 LOL but its ln2waste already...
its only around 50w-75..when pushed really hard..
hows your bios running? also how many flasks do you have already? 3 seems not enough for multi pots...
Hey guys, just wanna share (nothing special) but you all know the feeling: your 1st LN2 bench session you never forget ;)
Took me 10L of LN2 to get used to the coldbug of the mobo and the processor and the countless times to get used to the poring without making the cpu freeze... Whatsup with that! I already ordered a 48L dewar and now will have 60L ln2 for benching soon :D
I have an immediate goal to beat: regain my 1st place o SuperPi 1m Q9650 category that was shattered on the 1st stage of the HWBOT Country Cup 2009 :mad:
I'm almost there got my best run: 9.125s and the WR is 9.094s. I did not try use 2:40 as a divider all my runs where at 1:1 and the WR was with a 2:40 divider. If anybody has any tips on what to improve to get this Spi_1m?
I will get more LN2 today to hopefully get done with the Q9650 and move on. I still need one of these to get the PCMark05: Fusion IO Xtreme
Enough talking here's a short vid: http://www.youtube.com/watch?v=MCf7LRrNmio
very clean setup man, i love the insulation! unlike chew's insulation LOOOOL
Hy guys..
Im gonna join a dutch bench team, just wanted to say good luck and have fun and bye.. ill still hang around here to chat if thats ok
Cu
For benching on a REX a 6GB set would be overkill, though you need to keep in mind it's futureproof in case you want to switch to i7 some day.
DDR3 D9s can only be found on ebay these days, the only firm producing new stock is CSX as far as I know, and you can't get them in the US.
You have PM! ;)
No, that's Ronald's ( r00n's ) ramlist! :)
You put out some nice results yesterday! Congrats on breaking 300 points too! :up:
What RAM are you running? Did you decide on a new kit or will you just use the old one?
Most likely cold bug will be between -20 and -40C from what I heard, remember the memory controller is the culprit for most coldbugging i7s these days. Good thing is you will be able to run better timings and speed but it won't use lots of ln2.
Great results for your first ln2 session! You have the raw MHz to make it happen!
Did you try the PI tweaker program?
Good luck with your new team!
I have 2 flasks of 40oz each. What do you mean by bios running (vnb volts)?
I can also watercool the NB with 5oC water.
Thanks mate :up:
Thanks man! I did a 9.110s run today and got 2nd place but I'm missing by 0.016ms!!!!!!! My cpu won't accept any more volts 1.588vcore is max so far for a stable win boot. So it doesn't scale that well with the cold.
So I have to get those 0.016ms with tweaks. Am I missing something or the OCX Spi Tweaker is only helpfull with 32m? I never tried using it for Spi 1m.
Any other tips on how to get those 0.016ms?
I'm running striped WinXP SP3 with IDE drive.
large system cache enabled or not ? maxem used ? booting on 2 cores ? almost all services killed ? tried running a few times 16k before,... lower TRFC, tighten Tras ?
does LSC help for 1M? els you could try that, google largesystemcache
it does a little...but it also introduce some latency..
tried two cores only?
did you set real time priority on core1? core0 handles immediate process...
killed explorer.exe?
hmmm that max voltage limit sucks..hmmm you need more..i wonder if there's a quick mod for it...
drop the tras to 4..have you tried that?
wooo thanks for the hints..you're always welcome to bench for team.xs :D
D'oh, that was close...
Can't you get any more speed on the RAM?
4-4-4-12 on 1:1 divider?
5-5-5-15 on 5:6 divider?
5-4-4-15 35 at your current settings?
I'm sure the Quad is killing the NB but the last suggestion should be possible?!
For 1M you need to run CDT IV, did you do that?
You'll have PM in a minute! ;)
Tried ramdisk for 1M? dont use it in combination with maxmem, unless you reserved enough memory for both ofcourse ;)
I'm pushing harder today with the single 5970.....
Managed to get well in the top 20 for 3dmark vantage! :D
[and yes I have a FM link ;)]
Forget the 8400 GS cups... gotta max out this 5970 first! :p:
Here are some pictures of the rig... Enjoy!
Update: with these submissions we are going to be over 8000 points even with a member loss today! :)
don't stop squeezing everypoint :)
excellent vantage run :D
I'm afraid I lost my favourite HD5870 :( A vmem mod gone wrong, it seems like I killed both of those MVDDQ/MVDDC regulators/mosfets. Time to mod the second one :D
Thanks for the tips guys gonna try all those tomorrow :up:
EDIT:
Should SPi1m and OCX Tweaker be on the same RAMDISK?
After the waza folder is created will it always fill the RAMDISK entire space?
