F8H doing prime like 43m now and nps
gona do 2 hours of prime if no nps its stable for me
MD, nice! :up: great combo of thuban and D14.
I wonder how it looks between d14 and memory modules on the gigabyte mobo regarding space? I'd like see photos how much distance is between them. Especially at height if d14 runs triple fans :p:
http://img202.imageshack.us/img202/2878/spaceor.jpg
Uploaded with ImageShack.us
this modules still have that like shark teeth and still fit
no doubt about it, F8h bios is flaky at best, i set it to 14x save and exit, and it sometimes boots up at 14.5.
Even with cool and quiet disabled, its odd, sometimes doesnt move from low settings under load.
http://premium1.uploadit.org/bobbybo...eccccccccc.jpg
I haven't had any big big issues with the 1090t on this board, but i haven't had a lot of time to test yet either. I hit 4Ghz easy on air. i did notice it seems core throttling is alway sthere even with turbo off and CnQ off.
ive been using the F8H for a while now. so this is the most stable bios ive used. no probs so far with 1090T
http://img1.ak.crunchyroll.com/i/spi...06645_full.jpg
http://img3.ak.crunchyroll.com/i/spi...28818_full.jpg
Gigabyte GA-MA790FXT-UD5P F8H Bios
AMD Phenom II X6 1090T @4GHZ
Sapphire HD5970 2GB GDDR5 OC Ed.
2x2GB Kingston 1333 DDR3
Coolermaster V10 HSF
Zalman MFC2 Fan Controller
LG Supermulti Lightscribe DVD-RW- Modded Gigabyte 3D Aurora 570
ACER 24" P241w
4x WD 1TB Caviar Green@raid
Windows 7 64 Bit
Current 24/7 OC settings is 4ghz. cant get it stable at prime at 4.2ghz but it is benchable
http://img2.ak.crunchyroll.com/i/spi...77222_full.png
prime tested for 8 hours. (although the screenshot only shows 3 hours) f
yes its the most stable but its far from being at least 90%
and any one nows if giga will be puting up another bios F8 ? final not beta
still waiting for a better BIOS for my UD4P.
will GA-MA790FX-UDP5 be able to unlock extra cores on new Zosma chips?
x2 5000 ? are you kidding me? Thats nothing to be unlocked on it.
I've successfully unlocked 1x 550 C3, 2x 555 C3 on it using F8C bios (all all of them stable x4 3.7Ghz+), w/ only 1x 555 not unlockable that failed to boot into windows, but the board did unlock it also.
yes. not the athlon x2 5000+ but the athlon x2 5000. I've successfully unlocked 3 of them already. they're named Phenom FX 5000 with cpu-z. clocked at 2.2ghz with 8mb cache and for only 55$. it outperforms the athlon II x4 620 and is also a good overclocker :)
http://img3.ak.crunchyroll.com/i/spi...37630_full.png
i was not able to save a cpu-z screenshot (i've sold mine already) but i was able to save a 3dmark06 benchmark
I've got the D14 on this board and it clears Ripjaws with not much room to spare. Don't want to go any taller though.
I need to e-mail Noctua with pics so I can get the bracket to turn the D14 90*. I'm pretty sure when turned it will only cover the first two slots and leave the outer two open for taller dimms.
mastrdrver and MD, thanks! it will fit nicely with 4x gskill eco which use simple heatspreaders.. though im gonna use 60mm to blow from one side of memory modules.
if one got Corsair GTX, mastdrver solution looks good!
whats highest HTT you got on MA790FXT-UD5P?
i wanna try play htt with mobo.. just now im using F3L, it was not soo good as I thought.. maybe mem issue,.well..I try test again
my highest htt from bios is 317, from program in windows - 327 (super pi 32m stable) with bios F5 or F8c (i forgot which).
running now 1055T @ 300HTT 3000mhz nb
still need better memory support bios, I can go 1800mhz using 8x Dram divider or 5,33x (then HTT limits me) but thats impossible w/ 6,66x divider I cant even pass 1700mhz w/ mine Dominator Gts...
Cnq always on , and highest then 14x multi is not possible.
using F8H
Found new beta BIOS GA-MA790FXT-UD5P - F8j
-12.May 10
This came from dinos22 on TT forum:
Beta BIOS GA-MA790FXT-UD5P - F8k
-29.June 10
Fix some issues according to:
http://forums.tweaktown.com/f69/giga...tml#post359014
Links above uploaded to fileden.
