1. Why is it that I cannot run my 2000MHz memory in my new Core i7 system?
To understand this note the maximum QPI link speed we mentioned earlier. Using the simple ratio we defined, we can see that with the maximum QPI link speed of 4.0GHz we can have a theoretical maximum Uncore of 4.0GHz and a maximum memory speed of 2.0GHz. These however are only theoretical maximums and are by no means guaranteed. For starters, QPI and Uncore cannot be run at the same speed as any clock oscillations can result in a crash if the ratio of QPI to Uncore ever falls below 1:1. Therefore, Uncore must always be below QPI to avoid this, and preferably below the 8:9 Uncore to QPI ratio to guarantee stability. Consequently, if we cannot achieve 4.0GHz Uncore, this means that we absolutely cannot achieve 2.0GHz memory and we can therefore not guarantee any stability for 2.0GHz memory. Technically, the maximum DRAM speed for a stable system is equal to ((Max. Uncore) / (Safe QPI:Uncore Ratio)) / 2 or (4.0GHz / 9:8) / 2 = 1.777GHz. In between 1.777GHz DRAM and 2.0GHz DRAM you are likely to experience some level of instability over the long term. Past 2.0GHz you are just plain lucky.
