Kevin1970
This irq_not_less_or_equal is a memory problem.
So you either need better BIOS settings or your memory has problems.
Try default BIOS settings with 2v Vmem, 1.3v HT and 1.36 NB.
In case you have 4GB of system memory or more, relax tRFC.
Check your memory with Vista memtest (press tab during boot) or memtest 86+ (the latest version).
×§ñåkê×
Last night I was watching videos for hours, with nero showtime (vista 64).
Guacomole
What kind of NB cooling do you use to get 52°C SPP?
Two questions for everyone.
1. UPDT DMI error
Whenever I run everest, or Probe II or any other program reading sensors (real temp is a bright exception - what a great CPU temp program), the backlight comes on and after a while it states "UPDT DMI"
Then even if my system is perfectly stable otherwise, I sometimes (not always) get strange behavior from games or video playback including crashes.
Now I always restart my PC after I open any of these programs and never experience any problems this way.
Did anyone else notice that? The backlight (reads the time) should not light up or give me this UPDT DMI error. This is a BIOS problem.
2. nvstor64 error
A second problem I have is with the latest nvidia nforce chipset drivers.
With a 1TB disk in jbod I get in event viewer (computer managment) an nvstor64 error "A parity error was detected on \Device\RaidPort1".
This is not the case with smaller disks (ie my 250GB Hitatchi disks).
The previous 9.99 SATA RAID driver has no problems.
I need to completely remove the newest driver to get rid of this error.
Otherwise I keep getting it even with 9.99 drivers.
The disk is OK. I suspect there is something wrong with Vista 64 recognizing large perpendicular disks.
For example you may try a cmd window under Vista with any of the following commands on your disks
winsat disk -ran -write -drive c -v
winsat disk -flush -drive c -v
I get this "Error: Failed to properly assess the disk" only on the 1TB disk. My 250GB disks are OK.
On the other hand read benching the 1TB disk is OK
winsat disk -seq -read -drive c -count 1 -iocount 256 -seqsize 65536 -v
Nice bench. Have a look. This is a copy paste output I got from my raid-0 2X250GB.
Run[1] Type[0x01000001] Zone[0] - 101.053227 MB/s
Run[1] Type[0x01000001] Zone[1] - 107.536913 MB/s
Run[1] Type[0x01000001] Zone[2] - 109.020224 MB/s
Run[1] Type[0x01000001] Zone[3] - 109.357951 MB/s
Run[1] Type[0x01000001] Zone[4] - 103.364141 MB/s
Run[1] Type[0x01000001] Zone[5] - 103.520928 MB/s
Run[1] Type[0x01000001] Zone[6] - 96.963985 MB/s
Run[1] Type[0x01000001] Zone[7] - 86.867162 MB/s
Run[1] Type[0x01000001] Zone[8] - 95.087291 MB/s
Run[1] Type[0x01000001] Zone[9] - 87.580111 MB/s
Run[1] Type[0x01000001] Zone[10] - 88.480483 MB/s
Run[1] Type[0x01000001] Zone[11] - 78.554025 MB/s
Run[1] Type[0x01000001] Zone[12] - 71.082868 MB/s
Run[1] Type[0x01000001] Zone[13] - 74.031876 MB/s
Run[1] Type[0x01000001] Zone[14] - 68.966219 MB/s
Run[1] Type[0x01000001] Zone[15] - 61.795216 MB/s
> Run Time 00:00:12.53
> Disk Performance 108.37 MB/s
What is wrong with large (1TB and perpendicular?) disks?
Do you have the same problem with your disks?
Smart disk and hard disk spread spectrum control - BIOS behavior
In case you want to enable smart disk and or spread spectrum control in BIOS, do it before you create any raid.
Otherwise you end up with conflicts. The same happens with the latest Nvidia Nforce SATA IDE and SATA RAID drivers and the RAIDTOOL (do not install this).
For example. You create your raid and then you decide to enable smart disk.
This way, your raid disks do not update to support SMART operation and the non RAID disks update to support SMART.
The same is true for spread spectrum (enabling or disabling it). In case you have spread spectrum enabled on your disks, you need to enable it in BIOS, before you enable RAID.
