The same temperature as CPU. Is this idle or under load?
I recall that the according to Intel specs, the upper limit for the NB is 92C.
quick question fellas, wich do you think will give me a better performance overall, 413x9 = 3.717ghz with mem @ 550 with a bandwidth of 9050, or 450x8 = 3.6ghz mem at 540 with a bandwidth of 9300..........wich would you keep??? thanks.
about the 1.9v at my ram. What does that mean?
myself i would keep the one that performs the best for the longest on a hot day after extreme load/gaming..
Newest BIOS settings.
BIOS 0505
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8
FSB Frequency :450
FSB Strap to North Bridge :AUTO
PCI-E Frequency: 120
DRAM Frequency: DDR2-900
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 4
RAS# to CAS# Delay : 4
RAS# Precharge : 4
RAS# ActivateTime : 10
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 25
Write Recovery Time : 3
Read to Precharge Time : 3
Read to Write Delay (S/D) : 7
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: ENABLED
Ai Clock Twister : STRONG
Transaction Booster : ENABLED (1)
CPU Voltage : 1.4250v
CPU PLL Voltage : 1.5v
North Bridge Voltage : 1.49v
DRAM Voltage : 2.08v
FSB Termination Voltage : 1.4v
South Bridge Voltage : AUTO
Loadline Calibration : ENABLED
CPU GTL Reference : .63x
North Bridge GTL Reference : .67x
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : ENABLED
PLL/DRAM overvolt by .1-.14v about so adjusted to compensate. This is stable thus far 24hr Blend priority9
Hope it helps someone.
Thanks, that is wonderful. I can't get mine stable at 425 with those settings though. I tried upping the voltages with no luck. Did you experience that raising any particular voltage limited your OC compared to a lower voltage?
I have Reaper PC9200 memory. Can anyone give me some suggestions on mem settings to try in order to get a higher OC? My men should handle speeds close to 600..
thanks
have this mb on order with a q6600 g0 and G.SKILL 4GB(2 x 2GB) DDR2 1000 what setting do i have to change for no oc
coming from a commando i had to set my corsair 8500c5's
to (5-5-5-15) 2.2v manually or it would eat them
or can set all to auto
thanks
Hey alex is that Asus Probe readout or by a Dimm? Or is Asus probe pretty accurate?Quote:
I have the same ram mate, works pretty fine on all the baords I have tested so far , not much to change just ram frequency and voltage for ram, be carefull the baord overvolts the ram , works fine here at 2.0 setting, if it doesn't boot disable static read control... Board OC's fine to 450FSB ( keep ram at 900mhz ) Nb at 1.35,...
- Ratio CMOS Setting : 9
FSB Frequency :AUTO
PCI-E Frequency: 101
DRAM Frequency: DDR2-1000
DRAM Command Rate : AUTO
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
Ai Clock Twister : AUTO
Transaction Booster : AUTO
CPU Voltage : AUTO
CPU PLL Voltage : AUTO
North Bridge Voltage : AUTO
DRAM Voltage : 2.0 (board overvolts so you will end up around 2.04)
FSB Termination Voltage : AUTO
CPU GTL Reference : AUTO
North Bridge GTL Reference : AUTO
I see you guys going all high on the NB voltages, pretty high to me, I can run 450FSB with only 1.35 on the NB,... though I have to disable static read control then in the bios otherwise it will reboot when loading windows, though the CPU is fine at 3.6 ( so 450 x 8 and ram at 900mhz then ), haven't primed it (yet) but folds on all 4 cores at 100% ( better use of power then useless Prime to me) and has shown no hickups when gaming or sortlike...
Anyone share to update me on the NB voltages ?
Is there much advantage to gain
Hi, I've just installed water cooling but is it normal for my motherboard and CPU temps to reported as extremely high by both probe and everest? At the moment I'm running Prime and my CPU core temps are between 48-52c but my CPU temps shows 218c and my motherboard temps is 199c, lol it's going to catch fire :eek:
Thanks...
ChrisC
I dont know if this will help someone but most of my settings are at AUTO, achieves 3.74ghz stable, have clocked BFG8800GTX cards from stock OC standard to 640Mhz Core 1000Mhz (effective 2000Mhz) with Riva Tuner.
achieves
3dMark20001 66595
3DMark06 14415
Have been running 24/7 last three days, Under load Temps reach 55 GPU and 50 max on everything else, probably because watercooling all in one loop.
Has anyone got any suggestions as to how i can improve on this. I have been looking at MemSet but have not used it as yet. I would be interested to know Loco what timings and what dividers you are now achieving with the Ballisitic Sticks you have?
I have a lot of probs in Vista with 8800 keeps coming up with Stuck in Thread Error, I just hope driver maturity will rectify this. Anyone else any problems with this board and 8800 and Vista?
BIOS 0504
Extreme Tweaker
FSB Frequency :466
PCI-E Frequency: 100
DRAM Frequency: DDR2-1120
CAS# Latency : 5
RAS# Precharge : 5
DRAM Static Read Control: AUTO
Transaction Booster : DISABLED (AUTO) cant rem but default
CPU Voltage :AUTO
DRAM Voltage : 2.00v
Loadline Calibration : AUTO
Hi to all, subscribed.
Got mine two days ago, immediately upgraded to 505.
The board is Maximazing! I'm Loving it. (Asus Fanatic:D ).
With the right bios this thing will fly, who needs DFI or Gigabyte DQ/noIQ!.
Right now I'm just waiting for newer bios,, early next month maybe.
i just changed to the 505 bios from the shipped 401 and wow i have to say every voltage is over by .1 to .13 except cpu vcore and the sb voltages. be careful flashing to this bios if you had settings from the original bios they most likely wont work.
Anybody got an Auzentech Prelude running with this board & Vista X64?
As for the life of me i can't get it to work,the driver & software installs ok but when i double click the "Console Launcher" or "Audio Console" icons i get the following error.
"Unable to find audio device.Please make sure that your audio device is enabled & installed with it's driver"
Or
"This software is not compatable with the installed device"
In device manager the driver is installed & has no yellow question mark next to it?
@ChaosMinionX
Have you tried to run stable at lower chipset voltages?
Is this THE last ddr2 board to own? Just nuked my commando.:mad:
That was the lowest I could get with my ram timings/speed and running 4GB of it.
I am having a problem recently after 1 of my sticks died, that when I restart in windows the overclock fails for some reason, and the comp double boots to let me change it so it works...never ever had this happen before, would it be possible my other RAM is damaged but not erroring in memtest? Just a shot in the dark I suppose.
Anyone know of a good way to set up a couple fans for the NB and SB without removing the heatsinks it came with? I'm not ready to do water cooling yet, but when I do I'm thinking about the ZALMAN RESERATOR 1.
http://www.newegg.com/Product/Produc...82E16835118111
What does everyone think about the ZALMAN RESERATOR 1?
