The vcore is the max in the bios!:)Quote:
Thanks I'll try it soon:up:Quote:
Originally Posted by hipro5
That they say in placing BIOS screens for maximum overclocking success in aw9d-max? :)
Damn......I can't hit 500MHz fsb.....I stack at 496MHz.......:( :mad:
I wish my board had this limit :fact:
can't install uGuru in Vista , so sad.....
hey,my hero, we'r expecting ur ultimated mods:banana: congrates 496fsb, that's awesome, im stock at 450 :(Quote:
it seems my cpu comes very volt hungry after 350x10 to get maxium stability, 3.6ghz@1.45v is no problem but to get it 5h orthos stable it required 1.52v and 3.7ghz is running orthos@1.54v atm. btw it's not a very good idea to turn the comp on without wc system running i got 79c idle temps :D and that was only with uguru O_O
Just want to thank everyone in this thread. I put a e6600 together Fri night based on the infomation here. No problems at all, very stable.
E6600@3.2g, 1.4v, 52c load, 356fsb
AW9D-Max, MCH@1.55v
SuperTalent DDR800@2.2v 4-4-3-8
This thing is putting out Seti WU's twice as fast as my Opty165@2.42g..
Waiting on my UFO-U2 to get here. Should get it higher with water...
PA120.3
Apogee
MCW30
DD Tyee
MCP355/Alphacooltop.
I've submitted an email to Abit asking for uGuru Vista Beta......
Run installation in windows xp sp2 compatibility mode. worked for me.Quote:
Originally Posted by kenofstephen
let me try, thanks !:toast:Quote:
Originally Posted by Zucker2k
something wrong here.....Quote:
http://i82.photobucket.com/albums/j2...tephen/bug.jpg
Did you reboot? Also, what version of Vista are you running? Actually, it seems ur version of UGuru is different from mine. I just run the installation straight from the CD and mine has no LED Effect Control.Quote:
I got this from Abit's site, apart from this problem,Quote:
whenever I press "OK", "Cancel", "Apply" , the whole system freezes and I need to cold boot.....
Do you have voltage monitoring and all the other settings enabled in the bios? Dunno, but if you haven't you may wanna try that first.Quote:
same bios settings as I ran Win. XP, no problem, I'll install XP SP2 on another hard drive...Quote:
well with crystal i can change the multiplier and it doesn't bug so badly(orthos and core temp still show something else than it really is).from bios max fsb with 6-9x multi is 320 after that it goes all wrong and even if i set 320x9 from bios and then clock from windows it doesn't work, but with crystal it works pretty good.
And i can use 4:5 ram ratio with ram speed 438 or lower after that it's fail fail fail, 1:1 works luckily and i can use tighter timings :) did a quick try with 8x400 and result was: FREEZE but i was using 4:5...now started little bit lower and atm orthos is running 9x385 and ram is 1:1. i'm pretty sure i can't hit 4ghz with this cpu without much higher vcore so now my goal is to at least get my ram speed where it should be and that is 450mhz and that's only stock speed these sticks should do 500mhz with no problem.(wow long post..)
oh yeah what was the speed range where ppl had problems, 395-410 or something?
I have exactly the same situation. Easy until 3.4GHz, hungry after 3.5GHz. Orthos stability comes with VCore way up while Vmch increase doesn't help so much.Quote:
Originally Posted by Keiki
yep but luckily to get it stable at games and so on it works fine with lower volts but of course maximum stability is the best.Quote:
Originally Posted by Madellga
and another question: anybody know which temp is what in uguru? i mean those pwm1-4 and system?
EDIIIT: 395x9 going now 40min orthos.
I tried that too but nothing seamed to happen for some seconds and then I had a restart again.Has anyone else the same problem?I have 2X7800GTXs if it has something to do.I also find strange that even with watercooled chipset I can run pi @441fsb with 1.8(real)vmch but not with 1.83/1.85....Quote:
Anyway,I think I 'll just relax and wait for the new chipsets from ATI and NVIDIA.
This is something that goes unexplained, its not the SLI causing the problem its the board, On the Asus P5W DH it was in bios and could be adjusted with out lock up.Quote:
Originally Posted by Phil The Greek
Try also PCI Latency = 128 OR 255.....Quote:
As for the VMCH, try to see IF the chipset has good contact with the heatsink...
Damn Hipro :eek:Quote:
What's your secret? Water Cooled NB???
Can you post some information on the key settings to get high FSB on the AW9D-MAX?
Yess Master !! what your secret ??:toast: :toast: :toast: :toast: :toast: :toast:
