need help to get 3.4 and 3.6 stable
These settings work for 3.2 Ghz
Advanced -> JumperFree Conf.:
AI Tuning - Manual
CPU Freq. - 356 (which will give you 3.2 ghz)
DRAM Freq. - AUTO
PCI-E Freq. - 100
PCI Clock - 33.33 MHz
Spread Spectrum - Disabled
Memory Voltage - 2.10V
CPU Vcore - 1.36 (I got lots of conflicting opinions on this option. Some people had it as high as 1.45
(all other settings on this page - Auto)
There are settings for Northbridge voltage and southbridge voltage that I leave to auto.
Advanced -> CPU Conf.:
Modify Ratio - DISABLED
C1E - DISABLED
Max CPUID - Disabled
Vanderpool - Enabled
CPU TM - DISABLED
Execute Disable - DISABLED
PECI - Disabled
Im running e6600, p5b deluxe, corsair pc6400 5-5-5-12. Scythe Infinity
bios 0711
MY dram is set to auto im getting 5-6-6-18
Ive tried to raise the cpu freq, getting conflicting answers on what the vcore
should then be. and do i need to change the dram freq.
So basically does anyone have the exact settings for 3.4 ghz and for 3.6 Ghz
CPU freq ??
vcore voltage ??
dram ???
I got 3.6 Ghz to work WOW
AI Tuning - Manual
CPU Freq. - 400 (which will give you 3.6 ghz)
DRAM Freq. - AUTO
PCI-E Freq. - 100
Memory Voltage - 2.25V
CPU Vcore - 1.5875
FSB TV - 1.4
NB - 1.45
SB - 1.5
C1E - DISABLED
CPU TM - DISABLED
PECI - Disabled
Still my memory is supposed to be 5-5-5-12 and it
is currently running at 5-6-6-18.
Im a little concerned about the vcore so high.
But my real question is temps???
CPU at idle is between 49 and 50c I figure ill go as high as 57c during a stress
test. What are safe ranges, cuz 3.6 sure aint worth new parts.
