Utnorris
That is crazy....just simply crazy:up:.
Utnorris
after some, ummm, input from waterlogged...
and suggestion from lyl:Quote:
Oh yay! An Alphacool res with the aluminum caps. Mine broke just sitting on top of a bunch of spare parts in a box just like anything made by Tt.
waterlogged
http://img264.imageshack.us/img264/7264/acrespk1.jpg
I have removed the ac res and replaced it with an EK..can't even compare the quality...EK is so far beyond the alphacool res. Also ran the tubing into the top of res reducing tubing run length.Quote:
a potential mod could be to tap the side of that res near the top for an inlet (water flowing from the radiator) or get one that already has it like the EK. it would eliminate the long tubing run going down to the bottom, and would make the loop OH so clean.
http://img244.imageshack.us/img244/7379/pic4ov0.jpg
http://img151.imageshack.us/img151/6858/dscn3040rx1.jpg
http://img153.imageshack.us/img153/1830/dscn3039lw0.jpg
http://img134.imageshack.us/img134/9643/dscn3038mc9.jpg
Black Tygon R3400 14/11mm
http://www.djstudio.eu/pictures/scre.../P1010531s.jpg
Cosmos S
http://www.djstudio.eu/pictures/scre.../P1010534s.jpg
@ DJstudio this thread isnt really the place for a worklog mate, you should make a thread in the worklog section.
I agree, post it when it's done and in all its glory.
I'd rather see pics of his empty case and drill than your blabber. I always enjoy revisiting CyberDruid's dusty old beast when he reposts it too *hint*. ;)
Removed my 8800GTX and had to patch up my loop with a bit of copper (all I had in the garage) while I wait for my EK-FC4870X2-N. Also upgraded power supply which is why the cables aren't routed through the tray holes behind motherboard. I'm actually waiting for core i7 so I can get rid of my Blitz Extreme.
Can't really see in second pic but also got rid of my Core Series waiting for v2. Need to get my D400 out and take some real pictures.
@RCG_Bex: Yep! E8400@4.05GHz, 4870x2, Blitz Extreme, 2GB XMS3, HX1000W, 2x Velociraptor 150GB [Raid 0], 2x OCZ Core SSD 64GB [Raid 0], Auzen X-Fi Prelude... D-tek Fusion, PA120.3, Scythe SFlex, Laing D5 Vario.... TJ07.
Arse those some SSD's I spy?
~Bex
rider,
nice job. it looke like it will fly
One more Cosmos S wc build;)
Link to the photos
@ManoWaari: Don't be lazy, edit the pictures into the thread. :p: That's a lot of tubing, somehow seems like you could cut down the amount used. I could be mistaken though, nice and clean build!
@johnp1983: Is the Ybris block giving you good temps?
:O
good job john, looks good. i love the tracers and the ybris block.
what type of tubing are you using?
its almost there
http://i192.photobucket.com/albums/z...IMG_0060-1.jpg
but
my project is held :(
http://www.xtremesystems.org/forums/...=197718&page=2
Nice build Sherif!!
The sleeve bearings die quicker if you push air upwards.
Great job Waari!
Not really the best WC parts out there, but man that is slick! elegant! :up:
:shock: WOW!!!!!!!!
~Bex
