BP Rotary fittings . . .. . :up:
Take a night shot!
Take a night shot!
Switched my 2nd loop from its failed pink idea to black to extend the green/black theme throughout.
Personally I think its much better, hope you agree!
http://i20.photobucket.com/albums/b2..._/DSC04179.jpg
http://i20.photobucket.com/albums/b2..._/DSC04182.jpg
and with its new twin :) my colourmatched xbox
http://i20.photobucket.com/albums/b2..._/DSC04183.jpg
Just did a daytime snap too :)
http://i20.photobucket.com/albums/b2..._/DSC04186.jpg
Nice. It looks way better without the pink. That Xbox is pretty sweet too.
the green is so sweet! where the hell is the dvd drive?
On the desk :D
yeah, on the right of the desk there's my old 5.25 sata dvdrw, I made an extended sata to esata cable and a molex to sata power cable to I can run standard DVDRW and HDDs from my desktop :)
Someday I'll make a housing, probably in bright green :)
Hah I like that front panel mod on the PC7. Who needs optical devices anyway.
TouGe nice build :)
BP fittings l00ks perfect ;]
Way too many unclamped tubes? Even zip tied would be good.
agreed, and then someone's gonna come around, telling about a hose that got detached from the pump or the radiator, and ask "how the hell could that happen :confused: , you guys think my mb is still OK etc...etc..." Just to say that not using clamps on hose/barbs or compression fittings all the way is suicidal. Accidents ? Some of you guys are just asking for it ;)
As long that the tube is 7/16" ID I dont see the need for clamps or zips.
This is my version of Lian Li 343b
http://i287.photobucket.com/albums/l...5291Medium.jpg
http://i287.photobucket.com/albums/l...5277Medium.jpg
http://i287.photobucket.com/albums/l...5207Medium.jpg
http://i287.photobucket.com/albums/l...5220Medium.jpg
http://i287.photobucket.com/albums/l...5225Medium.jpg
http://i287.photobucket.com/albums/l...5236Medium.jpg
http://i287.photobucket.com/albums/l...5249Medium.jpg
http://i287.photobucket.com/albums/l...5283Medium.jpg
http://i287.photobucket.com/albums/l...5242Medium.jpg
http://i287.photobucket.com/albums/l...5230Medium.jpg
Hope U like IT
:up: Thanks guys...Definitely loving the BP fittings.
Who are you talking to? All my fittings are clamped with the exception of the BP fittings on the DD block. I'm not concerned about leaks since I can barely pull the tube from the fitting to begin with, so......
I think horizontal layout is better in terms of GPU waterblocks coz usualy they are very heavy and they tend to bend a card. with this configuration it does not matter how heavy gpu block is.
Will not bend a card.
Thanks for comments
Matias23, what coolant is the yellow?
f1 one i think ;)
Matias23 very nice man
ps check inbox ;)
is that aimed at me?
its been built abuot a year now with no leaks, its 7/16 tubing over fat 1/2" barbs and its so tight I needed to heat the ends of the tubing in boiling water to get them over the barbs and getting them back off again is a nightmare.
I'm happy, I know what I'm doing tbh been around the block a few times on this and I'm much happier with 7/16 and no clips/ties than with 1/2" with clips etc... the tubing is literally moulded onto the barbs.
Hello
my system at night how to find their quality?
http://img.skitch.com/20080817-b4bfs...9g.preview.jpg
matt100 Sweet build! Very similar to what I am trying to achieve! Except my case is smaller and probably not quite as well built! I really only have space for one internal loop. If I add a second one it will have to be external, which is not what I am after.
emu
http://i58.photobucket.com/albums/g2...Picture001.jpg
http://i58.photobucket.com/albums/g2...Picture002.jpg
http://i58.photobucket.com/albums/g2...Picture003.jpg
http://i58.photobucket.com/albums/g2...Picture004.jpg
http://i58.photobucket.com/albums/g2...cture005-1.jpg
http://i58.photobucket.com/albums/g2...cture008-1.jpg
http://i58.photobucket.com/albums/g2...Picture009.jpg
