i really dont understand why this startup value is available...I just need a Vcore....but now it is here plz guide me a little....i have a 3700+SD that goes to 220FSB with st. vcore but then is needing a lot to go any further....
Startup means "basic" VCore. Just let it at "Auto" if you want, and play with VID X%. But everything counts on how much are you aiming to get.
Regards!
PS: Sorry if my english is not very good :P
I'm having a problem with 43 C NB chipset temps... How can i fix this?
43c isnt a problem on NB.....they can go to 65-70 (official DFI statement)
thx eru. problem was that my cpu acts kind of weird...up to 225 it dont need any xtra vcore, but above that it needs plenty....running 1,61 (should have been 1,65 but nvm) @245FSB isnt very good.....tried new bios and it is not RAM that is holding it back....it only gets about 40c on load, but i am only using a xp120 and a revoltec 120mm on it, so i am worried about giving more vcore......hoped that something about startup VID was slowing it down....
*** STOP: 0x0000000A (0x536461B6, 0x00000003, 0x8042CB5C)
IRQL_NOT_LESS_OR_EQUAL *** Address 0x8042CB5C base at 0x80400000,
DateStamp 39760637 -ntoskrnl.exe
I snooped a bit around some other forums 2 look 4 a solution to this.
But anyways, any of you know exactly what it is.
So far the solution I've come to is to disable 1 of the sata raid setups.
I have on controller 1 & 2 2 x sataII 250gb @ raid 0 and on controller 3 & 4 2 x sataI 160gb. And sometimes when i cooldboot the bluescreen kind'a just wrecks da day. The error not always been there, have had both raid setup's going for 4-5 weks now. but it's more often now. don't matter if board+cpu oc'ed or not. still same thing some days.
can any1 help.
How far do you think 4 512 sticks of OCZ Plat Rev 2 would overclock to...?
approx 333mhz(166FSB) or 400mhz(200FSB) depending on mobo and cpu....and only in 2T...4 sticks and oc just isnt an option with those cpus yet......
What's the whole Vdimm bug where Vdimm is applied prior to the system being on.
I unplugged my Seasonic 600W and then back in. Vdimm was 2.5 already even though system wasn't on. Turned it on and it goes to 3.3v as my VX needs...
Hi
I have a SLI-DR, can anyone tell me if the four sata slots of Silicon Image Raid controller are fixed so that is it possible to overclock without troubles at any fsb? is silicon image controller better than built in nforce4 nVidia one?
:confused:
Having issues:
Was strugling with some random reboots from the warm summer weather so I decided to turn off my computer. Well I turn it back on and it hangs on lights. I figure, oh cold boot, ohh so evil. So I flip the clear Cmos jumper and sit back and watch Seinfeld for awhile (~45 min)
Went back to my CPU, put the jumper back, boots to DFI NF4 Splash Screen and hangs, wont go to bios and wont go anywhere. So I try again, pull the battery this time, same thing. Safe boot, same thing. Flip the switch a couple times with jumper in position, hang on splash.
Any ideas to try? please give your advice!
Wasnt sure what to search on for this problem, so here it is
Last night i tried out my 2x256mb bh6 just out of interest. This morning i put my gig of tccd back in. Now if i use cas 2.5, I get the first POST screen showing mem timings/hdds/bios date etc, but it stops after that. There's meant to be the second bios screen that shows IRQ allocations etc, but i dont get that. Trying to enter bios also gets the same result.
If i take out one stick, it works fine. Put the other stick in by itself, also fine.
Have tried 510-2FIX, 510-3FIX and 623-3, all getting the same result.
This is all at stock 200HTT btw
@SDX:
Had the same problem with system in sig and TwinMOS SP new bh-5.
What I did to solve it:
Jumperblock 4V back to 3.3V
Clear CMOS once again
Fired up the system and booted nice into bios again
without changing anything else I put the vcore settings to fixed values (no auto)
Save bios
reboot
put memory on 3.2V
switch off
4V jumperblock back to 4V
switch on
everything fine again
could go to the usual settings as before (I stayed on the safe side this time)
Hope this will work for U 2...
I have had a hard time choosing between the A8N Sli Prem and the DFI nF4 SLI-DR... But it has been settled now.. Anyway I am getting the DFI, a A64 Venice 3500+, 2x512mb Corsair PC3200* (some standard paried up Dual-Channel kit, it is NOT Value S.) and most probably the XP-90 with a decent fan to handle the cooling.
But before I order and build my new rig I have a few questions for ya all..
Would I be able to use the XP-120 instead of the Xp-90 and still be able to use the Orange DIMMs when the m/b is normally mounted (not inverted atx)?
As far as I know the mem is TCCD, so is there a good modded bios for the Corsair mem using TCCD and a Venice?
Instead of creating a new thread I thought I might aswell ask here.... :)
any help appreciated
*means this memory:
Corsair XMS 1024MB (2x512) PC3200 400MHz TWINX1024-3200C2 (2-3-3-6).
bios 704-2BT works very nice for all kinds of ram...
Instead of XP120, I'd consider the Big Typhoon, best aircooler atm and no problem for orange slots...
Checked out the Big Typhoon now and it does seems nice... Big and very good cooling according to reviews.Quote:
Originally Posted by OneyedK
There is one thing though, in a forum one user claims that he had problems mounting it on a DFI LP nF4 and claimed that he had to come up with his own solution. Is that true or is he simply too stupid to mount it? :rolleyes:
Thanks for the tip and if I can clear out that little question I think I now excactly what to get... :)
Edit: been reading about the Big Typhoon a little more now... Both on DFI-street and here, think I am gonna get the XP-90c instead, don't feel like lapping the Big Typhoon, fix the backplate on the DFI/replace it. Thanks for the tip anyway.
A good friend of mine: JaDa@hardwareonline.be has the big typhoon mounted on a DFI nF4 SLI-DR... No problems whatsoever, you can always mail him if you have more questions...
battery out overnight worked!
yay
Need help, i think my Board is dying :(
a week ago i could run 2600 Mhz @ stock volts, 2770 @ 1,56 on my venice 3200+. Most of the time i ran 2770 with 180 div (~251 Mhz). Rams are Mushkin 3500 bh5. They should run at least 250 with 3,3v had them around 255 stable. But a few days ago a got a BSOD nearly every day sometimes a few of them a day. So i flashed Bios to 510 by Merlin. Problems stayed. So i flashed 704-2 BT Bios. Probls doesn' vanish so i examind the problem. Tried 230x10 with cpu @1,56v and Ram @3,2v => errors in memtest instantly :( i used the same 164 Tweaker settings which ran 250mhz stable a few days ago. So whats going on here ? want my overclock back :( Hope u guys can help me out. If u want to know details of my system just ask ;)
Are the memtest errors random or are they around a specific allocation?
Don't think tey are random, e.g. 230x10 Mhz and 3,2V (they must work at these settings) pass 3 or 4 of test #5 8 errors. Other example 250x10 3,3V (again they worked before) over 200 Errors first pass and even more after 2nd pass and so on. So wtf is going on here ?
you have active cooling im assuming?
Yes 120mm Fan above Rams. Changed nothing and that's curious
Try increasing Trfc if the errors occur near the end of test #5.
If that doesn't work, try the sticks separately...
Nothing changed on the lines of your PSU? Especially 3.3 and 5V ???
No no changes, PSU is OCZ Powerstream 600 W, lines stable as a rock :)
I think my DFI's CMOS Reloaded is borked. None of the fields can be renamed:
I can still type what I want to the fields but the text just don't appear there after pressing enter in the 3rd row. :confused:
The strange thing is that the last row from the 1st slot's description (excluding the 1st letter) apppears to the 1st row of the 4th slot IF I save settings to the 4th slot. :D
I've tried reflashing and clear CMOS - no effect.
btw. Where is the CMOS Reloaded stored? If I use another bios chip, the settings that were saved while the other chip was seated, are still there.
