@tiborrr,
I am thinking of my AMD stock HSF for vid card cooler as well, and got wonder how you managed to sit it on the vid card. Can you give some more pictures and hopefully get some instruction?
Thank you,
That HS on the graphics card looks wayyyy to heavy.
Are you sure it's safe? I would add some kinda support or something.
my faulty workstation:
http://img359.imageshack.us/img359/1044/img8129no4.jpg
My new HR-01 arrived today :D. I've sent my Ultra-120 eXtreme back to the shop, because it was too convex.
http://img144.imageshack.us/img144/6821/dsc00822zf5.jpg
http://img502.imageshack.us/img502/1751/dsc00825ni9.jpg
http://img144.imageshack.us/img144/5220/dsc00827md5.jpg
Tomorrow it will be mount on my new DFI 680i LT Board :D
/\ you must hate Thermalright :ROTF:
I put my old system back together, ready to donate it to a friend. Too bad I had lost the clip for my cpu heatsink but I just fastened it with screws right through the cooler instead, same thing with the video card.
The cpu & gpu cooler make excellent contact :D
AMD Thunderbird 1.2ghz, Elsa GF2 pro
http://img523.imageshack.us/img523/1...e013ht4.th.jpg
http://img523.imageshack.us/img523/2...e002is7.th.jpg
Nice build you got there! :welcome: WELCOME TO XS!!!!!:welcome:
New board arrived 2 days ago :D
http://img259.imageshack.us/img259/5489/dsc00841ti6.jpg
IMO, why can't you put your X1900 (?) in the second PCI-E slot? This would allow for the 'reverse' mounting of the HR-03, thus improving temps (since heat rises). It would also provide airflow to the DFI NB cooler. Just my .02 :shrug:
Brendan
I don't like the reverse mounting, because then there is no airflow for the RAMs and the PWMs. The temps are very good at the VGA and the NB so there's no need to change anything ;)
Hehe, thanks :)
Unfortunatly a HR-05 doesn't fit on this board :(. The same problem with the HR-09, but I hope that Thermalright will release the version for the DFI and ABIT boards soon :)
http://img264.imageshack.us/img264/3138/72799798bd1.jpg
Tommy, does that HR-01's Fan Duct actually help anything ?
I don't have the fan duct, so I cant tell you if it helps
how much did the S1 VRM heatsink help with temps?
maybe the last pictures of my opteron-system. :(
http://img383.imageshack.us/img383/5236/img8772sd5.jpg
http://img383.imageshack.us/img383/1218/img8770gg9.jpg
http://img383.imageshack.us/img383/5396/img8773yy7.jpg
@LuckyNV: With the stock heatsink I had 100° and massiv graphic failures. Now I only have about 80-90° without an airflow :D:D:D
BTW, I had to cut a litte corrie to mount my HR-07 on my DFI 680i, because the condis are too close to the slots :(. But I think I've done it well :D
http://img140.imageshack.us/img140/2434/dsc00855cs5.jpg
