awesome score there Quad:toast: , im pretty much tapped out with mine...
thanks. that was quick:)
Tom look at : http://www.biwa.ne.jp/~yok/838RANK-NEW.htmQuote:
Originally posted by Tom Holck
Nice CCC
Thats nr 3:toast:
5'03 like u with a P4EE 3.2XE@5054MHz
but his OS is Win2003
why u dont try with this OS? :D
Hi cpulloverclock:toast:Quote:
Last week I downloaded 2003server 32 bit and
2003server 64Bit AMD.
yesteday I installed the 2003 32 bit, its work fine. Pre-results:
:rolleyes: might be a bit faster, only tried pifast low(:D) settings 3152 Mhz drop under 40. With XP sp1 and Win2000 it was a bit over 40
The 2003 bit64 don't work for now. It can only be installed from the boot-CD I have made. It make some adress error, when the first screen comes up. It might be some settings in SK8V bios??
There might also be a problem with ATI card driver (64 bit??) I think we have to use nVidia.:rolleyes:
I will go for the 32M with the 2003 son, and work on the 64bit AMD.
Now the 2003server AMD64bit work:
http://www.xtremesystems.org/forums/...723#post329723
Superpi new WR: 24.46:banana:
update 20.01.04 24.21::banana: :banana:
http://www.xtremesystems.org/forums/...229#post332229
Glad u got i working mate :toast: :banana:
this is my best.
Just quick note
Have not forgotten you all ;) just busy i'll get around to doing
an update this evening after i get back from work.
Regards
PMM
Tom; for u :
Uhhh. I have to hurry, if I'll be the first under 5 sek:p:
Yesteday got 2 new stik og corsair. Its the new version 1.1
Already tried they, can go 2-5-2-2:D
I have also tried 4 x 512 Mb but that is 2-3-6-2
Have to test some more, 4 is more onstable as 2.:rolleyes:
In about 2 weeks, my final Cascade-cooler is finich. It's only the prototype I'm using as this point.
The Final (18.18 PC 115C) can take 15-20% more load and a little better in temp. [2 18 cubik compressors working temp -115C]
It will help in 32M I think, it will bench at 3152-3200 but in M8 win-XP is still faster (3186 Mhz)
The 64 bit can do M8 5.05-5.06 at 3133-3152 Mhz but is not stable beon that.
Now the 3D work in server 2003 32 bit, but it is to slow only 100 in car high. Same settings in win2000 give 162!!
sorry Tom but :(
http://v-tec.hp.infoseek.co.jp/3339A...2100V-299S.JPG
awesome :slobber:
http://v-tec.hp.infoseek.co.jp/3339A...-2100V-25S.JPG
here's my first A64 effort
http://users.tpg.com.au/spark69/an50r/pifast45.jpg
still trying to sort out some decent CPU contact with this prom :(
45.02 on P4EE @ 4309... Looks nice for P4, though can't compare with big AMD guys...
http://alt.modlabs.net/45.02.gif
Minor improvement over my last result
http://users.tpg.com.au/spark69/an50r/pifast44.79.jpg
Cpulloverclock:)Quote:
Here you are, cpulloverclock
1. work done: Cpumark 406 at 3195, havent tried higher, done 400 at bootingspeed 3152
The M1 SuperPi test I now, "only" 27 sek, but VERY close to 26..
I can't beat the M8 sub 5 min at the moment. In 64 bit the Cpu gets to hot, and can't go pas 3151. In XP the speed need to be around 3250. I am not stabil at that speed yeat;)
New ER3500 ram comming soon, and the final Cascade in 14 days.
Then I will move sub 5 min in M8 and sub 24 min in M32.:banana:
But still improving:
wow, ouchhhhhhh 3224MHz :slobber: :toast:Quote:
Cpulloverclock:)
wait&see in 2 weeks
D@mn, you got a tough life Tom :D Keep up the great work.Quote:
In 64 bit the Cpu gets to hot, and can't go past 3151.
Got myself a new board, K8NNXP. The SK8N mysteriously ceased functioning :stick:
http://caprid.homestead.com/files/pi47.89air.jpg
Not to bad for a $20 Thermaltake HSF :)
STILL fighting with my OLD CPU........ :D
1:1 is the go......
http://www.adventurevision.com/somep...ast-46.20s.gif
(46.20s)
- A64 3200+@1.8v
- Shuttle AN50R
- Corsair XMS 3502v1.1@3.2v
- stock nVentiv MACH I
- Fortron Source 530w PS
It's running 265x10@2.5-2-2-11. I think it has a little left but I don't want to do anything stupid... yet. ;)
Inched up to 266x10 and almost broke 46...
http://www.adventurevision.com/somep...ast-46.03s.png
I'm pretty happy with this setup. ;)
Respect to the scores above :)
Now I'll show you my "awesome" score :D
http://home.planet.nl/~dikke332/pifast5663.jpg
Abit NF7-S v2.0
Barton 2600+ @ 11.5x220 @ 1.95v(yeah it's locked so what it clocks good) :D
Kingston HyperX PC3500 (Winbond CH5 chips) @ 11-2-2-2 (not very stable but pifast stable) ;)
11-2-3-2 results in 1 second slower pifast :(
P4EE at 255fsb...ok I guess.
And about 1 second off again :)
http://home.planet.nl/~dikke332/pifast5566.jpg
Duron 1400 L2 modded
ASUS A7N8X deluxe vmodded
2x 256mb Twinmos PC3200
http://home.kabelfoon.nl/~vnrswk/pifast1.jpg
holy mother of god! :eek:Quote:
i'm @ 56.6 ish w/ 245 x 10.5 2-2-2-11 on my Tbred :)
gonna try higher tonight :D
