thanks buddy !
108 x 51 mem on 2000+ 9-11-9-27 1T
http://img41.imageshack.us/img41/2447/5500108.png
Uploaded with ImageShack.us
Well, at least for me, it's as stable as 1850, but with added option for Extreme Tweaking and it plays good with Elpida Hypers.
There is one thing I noticed last night, that you could check for me, if you have time. And all you M4E guys. :)
Write Recovery time (tWR) is always set at 8, no matter the speed (1600/1866/2133) or Memory Boost, when set on Auto.
Thanks! :up:
Oh you guys are evil !! Sergio has been gigaexorcised... don't push that Bclock 24/7 man... it's not worth loosing the board...
2600K @ BCLK 108 X 50 = 5.4GHz
Asus Maximus IV Extreme-Z
GSkill RipjawsX 2200C7 2X2GB @ 2300MHz 7-10-7-27-1T
http://i458.photobucket.com/albums/q...2600K/108b.jpg
very nice !
I'm having a little problem here. I was using BIOS 1409 here without problems, now resolved now upgrade to version 1850, and the voltages are above the real values that I set in the BIOS.
In 1409 this did not happen, I decided to go back to this version, but the problem now persists in staying.
Example: set DRAM Voltage 1.65V (BIOS), real (sensor) is 1.68V, 0.03V in ever increasing, it happens DRAM Voltage, CPU PLL, VCCIO, VCCSA.
Does anyone know how to solve this now?
SS:
All options to AUTO in the BIOS, it looks like now:
http://www.abload.de/img/erromuz2.png
Don't know if it's the same problem but if they are anything like the sensor voltages on my P8P67-EVO then it may just be noisy readings. I noticed this on the EVO B2 and still there with the replacement B3. Using a multimeter showed at least the DRAM voltage was much steadier than the sensor would indicate.
voltages have always read a bit higher for me than what I set.
weird l0ud mine reads on all programs perfect what i set in bios
http://img638.imageshack.us/img638/116/5ghzsensor.png
dang would be nice to make the pics a bit bigger as no matter what i post it looks small
I really hope it's just an error of the sensor itself, because I could not return as it was before at all.
Here before the sensor showed values just as I left the BIOS.
Ex: All AUTO, showed 1.056V (VCCIO and VCCSA) showed DRAM 1.654V. Now the most is reading 0.03V at all options.
Here too was reading the voltages correctly andressergio. It was not until I update the BIOS and it started to happen. Any ideas?
Notice some of the hwmonitor volts are different to sensors, what sort of max/min do you get if left running awhile?[/QUOTE]
Looks good and doesn't break the board out to the right. A quick right click and view picture shows it in it's full glory, at least on FF.
yes hwmonitor does so, measure max and min, when load idle for ex, and volts are very accurate
Looks good and doesn't break the board out to the right. A quick right click and view picture shows it in it's full glory, at least on FF.[/QUOTE]
you meant click and goes to the link, pic do notha if i do righ click aint have that quick view
cheers
Sergio
almost there, this time with 2133C8 BBSE kit... :w
2600K @ 107.5 X 50
GSkill RipjawsX 2133C8 2X2GB @ 2293MHz 8-9-8-24-1T
http://i458.photobucket.com/albums/q...33c81075-1.jpg
nice owi i love 2x2 2133+ kits i have one of mushkins 2133 CL7 will try later for now look this
I2600K @ 100x56 2 cores 2 threads (not to give more volts to this nice chip)
2x4GB Patriot Xtreme 2133 9-11-9-27 1T
MIVE BIOS 1850
http://img194.imageshack.us/img194/9434/5600spi32.png
