I blame Copy-Paste! :yepp:
Fixed.
Edit: 1000th post of the thread! :D
4,5G done on air, ambient temp 23c
http://img19.imageshack.us/img19/5757/45gstable.th.jpg
batch #L938B402
4.65Ghz on above dew point water - Xeon W3680 Batch# 3013A739
My goal was to reach 100GFlops.
http://valid.canardpc.com/cache/banner/1445387.png
http://i176.photobucket.com/albums/w...x/465alinx.jpg
Here's a template:
Code:GIGABYTE GA-X58A-UD7 rev2
MB Intelligent Tweaker(M.I.T.)
> Advanced Frequency Settings [Press Enter]
CPU Clock Ratio............................: 30
CPU Frequency ........................(GHz): 4.65
> Advanced CPU Core Features [Press Enter]
Intel(R) Turbo Boost Tech..................: Disabled
CPU Cores Enabled..........................: All
CPU Multi Threading........................: Disabled
CPU Enhanced Halt (C1E)....................: Disabled
C3/C6/C7 State Support.....................: Disabled
CPU Thermal Monitor........................: Disabled
CPU EIST Function..........................: Disabled
Bi-Directional PROCHOT.....................: Disabled
QPI Clock Ratio............................: x36
QPI Link Speed........................(GHz): 5.58
Uncore Clock Ratio.........................: x21
Uncore Frequency......................(MHz): 3255
>>>>> Standard Clock Control
Base Clock(BCLK) Control...................: Enabled
BCLK Frequency(MHz)........................: 155
Extreme Memory Profile(X.M.P.).............: Disabled
System Memory Multiplier (SPD).............: 12
Memory Frequency(MHz)......................: 1860
PCI Express Frequency(MHz).................: 100
>>>>> Advanced Clock Control
CPU Clock Drive (mV).......................: 800
PCI Express Clock Drive (mV)...............: 900
CPU Clock Skew (ps)........................: 0
IOH Clock Skew (ps)........................: 0
> Advanced Memory Settings [Press Enter]
Performance Enhance........................: Standard
DRAM Timing Selectable (SPD)...............: Quick
Profile DDR Voltage........................: 1.5
Profile QPI Voltage........................: 1.175
Channel Interleaving.......................: 6
Rank Interleaving..........................: 4
>>>>> Channel A, B, & C
> Channel A, B, & C Timing Settings [Press Enter]
>>>>> Channel A, B, & C Standard Timing Control
Cas Latency Time...........................: 8
tRCD.......................................: 8
tRP........................................: 8
tRAS.......................................: 22
>>>>> Channel A, B, & C Advanced Timing Control
tRC........................................: Auto
tRRD ......................................: Auto
tWTR ......................................: Auto
tWR........................................: Auto
tWTP.......................................: Auto
tWL........................................: Auto
tRFC.......................................: 80
tRTP.......................................: Auto
tFAW.......................................: Auto
Command Rate (CMD) ........................: 1
>>>>> Channel A, B, & C Misc Timing Control
B2B CAS Delay..............................: -
Round Trip Latency.........................: Auto
> Channel A, B, & C Turnaround Setting [Press Enter]
>>>>> Channel A, B, & C Reads Followed By Reads
Different DIMMs............................: Auto
Different Ranks............................: Auto
On The Same Rank...........................: Auto
>>>>> Channel A, B, & C Writes Followed By Writes
> Advanced Voltage Settings [Press Enter]
>>> CPU
LoadLine Calibration.......................: L2
CPU Vcore..................................: 1.5375
xDynamic Vcore(DVID).......................: 0
QPI/VTT Voltage............................: 1.415
CPU PLL....................................: 1.4
>>> MCH/ICH
PCIE.......................................: Auto [1.5]
QPI PLL....................................: Auto [1.1]
IOH Core...................................: Normal [1.1]
ICH I/O....................................: Auto [1.5]
ICH Core...................................: Auto [1.1]
>>> Dram
DRAM Voltage...............................: 1.66
DRAM Termination...........................: .75
Ch-A Data VRef.............................: .75
Ch-B Data VRef.............................: .75
Ch-C Data VRef.............................: .75
Ch-A Address VRef..........................: .75
Ch-B Address VRef..........................: .75
Ch-C Address VRef..........................: .75
> Miscellaneous Settings [Press Enter]
Isochronous Support........................: Enabled
Virtualization Technology..................: Disabled
GOOC 2010 WWF Rev.2 Settings Only
GOOC Lean Mode.............................: On
GOOC extreme clock.........................: Enabled
GOOC extreme temp..........................: Disabled
heres my newest cpu.it does 4502 w/1.32v in xp but win7 x64 required
a bump in vcore from 1.362v to 1.368v in bios.1.34v load is still awesome:D
i7-920 #3849B018
Gigabyte X58A-UD5
custom water w/AC
4.5GHz HT on 1.34v
http://valid.canardpc.com/show_oc.php?id=1446295
4502 HT on DDR3-1715 9-9-9-24 1t
20 run LinX 42m Prime95 Blend
http://i51.tinypic.com/t0t5yu.jpg
http://i54.tinypic.com/2lsbfaw.jpg
Good job, everyone! :up:
Congrats on your golden batch chip, radaja! Took you a while to get one, eh? :D
Where on earth did you find a batch like that?! :D I'd have thought they'd all be long gone by now...
well this is my fourth golden 920,and ive been trying to match my first one ever since i sold it.
it was another 3849B018 and i sold it only after playing with it for about 2 weeks and i didnt know
much about i7's then.it was and still is the best one for low volts ive seen.this one is close but still not the same:D
i got it from someone at ocn who is also a great wellknown XS's member:up:
Batch# 3013A652 Core i7 970. Cooling Thermalright Silver Arrow.
http://img839.imageshack.us/img839/8462/linx451000.jpg
http://img837.imageshack.us/img837/1...validate01.jpg
http://valid.canardpc.com/show_oc.php?id=1444923
http://img822.imageshack.us/img822/4...pi5ghz1000.jpg
http://img213.imageshack.us/img213/7...ench121000.jpg
Thermalright Silver Arrow and Intel I7 970 5ghz
5GHz on air?! That's nuts :D
Zalbard.....my cpu is a W3680 and what do I have to do to get past The Nemisis?
Trying to find the minimum proc speed while still hitting 100 GFlops stable in Linx.
http://i176.photobucket.com/albums/w...x100GFlops.jpg
My 1year old result :)
Dekara | C2D E8600 [2C] @ 4510MHz | 1.312 | DFI P45-T2RS Plus | Air | Q820A606
http://img8.imageshack.us/img8/6276/...1vlinxx.th.jpg
Here's my entry....
Gigabyte GA-X58-UD3R Rev 2
Intel i7 950 FPO/Batch 3020A998
3 x 1GB OCZ Platinum PC3-12800 CL7
OCZ GameXStream1010W PSU
Prolimatech Megahalems RevB 1 x NMB-Mat 120mm Fan
2 x HD3870X2
http://i106.photobucket.com/albums/m...R1960CL81T.png
Replace linpack_xeon32 and xeon64 with those in this package (newer, 10.2.6.015).
Found a nice I7-950
wiener007 | Core i7 950 [4C 8T] @ 4519.7 MHz | 1.303 | Rampage III Extreme | Water | 3849B099
http://www.abload.de/thumb/4500-linxbfls.jpg
wow, nice i7 950 :)
Here is my 5-th "new" Xeon W3520 :D:
4C 8T
batch# - 3845A935@4567MHz
mobo - RIIIE
cooling - water: EK-Supreme HF, MCP355, Magicool Xtreme III
vcore @ 1.376V
http://img183.imageshack.us/img183/2...inx4567.th.jpg http://img51.imageshack.us/img51/958...x204567.th.jpg
