thx :) switch panel under construction.
there overall view of rig :rolleyes:
http://img230.imageshack.us/img230/7662/dsc2908hf.jpg
GX-Badangel@ Have you had any problems with you're sunbeam fancontroller what so ever?? Are you useing it on fans with leds on them.. Just useing it for the fans..
I have one just like it, but two of my outputs are dead and if i adjust the speed down once the leds start to blink.. Have to contact sunbeamtech about it, but i havent gottn to it yet
My second attempt at building a liquid cooled PC.
Built using the Corsair Obsidian 800D Full ATX Case.
Loop 01 (Blue)
- Tubing PrimoFlex Pro LRT UV Blue Tubing -3/8in. ID X 5/8in. OD (10ft)
- Coolant PrimoChill ICE Non-Conductive Water Cooling Coolant (32 oz.) - UV Blue
- Reservoir XSPC 5.25" Black Reservoir Bay w/ Blue LED
- Pump Swiftech MCP350 12 VDC Pump
- Radiator HardWare Labs GTX240
- CPU Block Swiftech GTZ
- MoBo Block EK-EVGA X58 Classified Full Board Waterblock
- Fittings Bitspower Compression Fitting-ID 3/8" OD 5/8" (x2)
- Fittings Bitspower Barb Fitting-ID 3/8" (x2)
- Fittings Bitspower G1/4 Dual Rotary 45-Degree Compression Fitting-ID 3/8" OD 5/8" (x4)
- Misc Parts Bitspower Acrylic T-Block, Bitspower Temp Sensor, Bitspower Male to Male G 1/4 Fitting
- Fans Cooler Master R4 120mm Blue LED Fan R4-L2R-20AC-GP (x3)
Loop 02 (Green)
- Tubing PrimoFlex Pro LRT UV Green Tubing -3/8in. ID X 5/8in. OD (10ft)
- Coolant PrimoChill ICE Non-Conductive Water Cooling Coolant (32 oz.) - UV Green
- Reservoir XSPC 5.25" Black Reservoir Bay w/ Green LED
- Radiator HardWare Labs X-Flow Extreme III
- GPU Block Thermaltake NG-4 (Will update the GPU blocks once the new 300 series cards arrive)
- Fittings Bitspower Compression Fitting-ID 3/8" OD 5/8" (x4)
- Fittings Bitspower G1/4 Dual Rotary 45-Degree Compression Fitting-ID 3/8" OD 5/8" (x2)
- Fans Cooler Master R4 120mm Blue LED Fan R4-L2R-20AC-GP (x2)
http://farm4.static.flickr.com/3494/...17aefc0f_b.jpg
http://farm3.static.flickr.com/2645/...52f616c7_b.jpg
http://farm3.static.flickr.com/2517/...63e124d5_b.jpg
http://farm4.static.flickr.com/3460/...4bacc3c6_b.jpg
Check out the Build Log here:
Build Log - Turambar: Corsair Obsidian 800D Liquid Cooled Dual Loop System :D
Still almost no lights, although it's working several months already. Not the first version though. Hardware changed during that time, too :)
Here's the setup 24/7:
MB: Asus M3A78-T - pretty old one, but was one of the few options on our market when I bought it.
CPU: AMD Phenom II 940 @ 3893MHz (0852BPAW)
RAM: 2x2GB OCZ Blade LV DDR2 @ 1222MHz
VC: Asus HD4890 ref @ 1050/4800
Case: CoolerMaster HAF932
PSU: CoolerMaster M700
WaterCooling:
CPU: D-Tek FuZion v2
NB: Swiftech MCW30
VC: EK-FC4890 LT
Rad: ThermoChill PA120.3
Pump: Swiftech MCP655
Reservoir: XSPC Bay
Tubing: Masterkleer 7/16" ID 5/8" OD
Coolant: Feser One Red UV
Some sleeving and other minor things.
http://img29.imageshack.us/img29/492/93415414.png http://img42.imageshack.us/img42/7986/img2395x.jpg
http://img340.imageshack.us/img340/3479/img2399.jpg
And one very old case next to the HAF..lookin' so silly :D
http://img402.imageshack.us/img402/6176/img2366t.jpg
so far this is wat i got.. my 2nd setup... still working on it
http://i37.tinypic.com/35l5m9w.jpg
"Cool" 1990 boom box mod
i7 965
Foxconn Bloodrage MB
6GB Crucial Ballstix
2 * EVGA 280 GTX SLI
DANGER DEN watercooling
X-Fi Pro SC with 750 Gigaworks Speakers
28" Hanns
300GB velociraptor
1.5 Tb storage
Tagan BZ Power supply
http://farm3.static.flickr.com/2510/...cc2fc12c_b.jpg
http://farm4.static.flickr.com/3425/...32aa97e9_b.jpg
http://farm4.static.flickr.com/3468/...52b58c96_b.jpg
you tube
http://www.youtube.com/watch?v=UHc444j-nIA
Link to work log
http://www.modders-inc.com/modules.p...ewtopic&t=3805
Link to coolermasterCase modcontest
http://www.coolermaster-usa.com/micr...st09/index.php
That is the most awesome thing i have ever seen! i want!
Welcome aboard jjsky5000 that is an awesome build; how you got all that in there is an amazing feat.
jjsky5000 you scared the hell out of me. I thought the 80's was coming back to haunt me with my old ghetto blaster! :rofl: Awesome job btw!
Well it was very hard. I about quit three times. i am glad i kept going. I am now cleaning the cuts it up abit with some UV trimming. I wanted to use my 1/2 green but i could get teh loops small enough to bend nicly so i went with 3/8. It is cool and powerful what more can you ask for.
full work log here on how it was all put in.
http://forum.coolermaster.com/viewtopic.php?f=9&t=13627
:welcome: jjsky5000! :D
That's one hell of a work, man! :up:
@ jjsky5000 - Man that is one of the flat out coolest and most inventive projects I have ever seen. I'll admit that at first I only saw the top picture you had posted, and I wasn't quite sure what I was looking at. After I saw the other two, I just had to go look at your worklog for it. The scope of vision and creativity here are absolutely amazing. To not only turn the boombox into a mod for a water cooled rig, but to also allow the original shape and visual scheme of the boombox to be held, while enhancing it in subtle and creative ways, AND having the system be effective, I'm just at a loss for how you came up with this. Well done! :clap::clap::clap::clap::clap:
wOw VERY NICE IDEA jj great work there :clap:
jjsky5000, great retro mod! :D
Respect dude, that's SO flucking beautiful! :eek2:
wow jjsky great job man :up:
Updated added link to worklog & video
Thanks. You should see the work log. I wasnt sure how I was going to fit it all in!!!! I kept testing pieces before i put them in (lol)
here my both x58 setup
http://i34.tinypic.com/23uzoya.jpg
New pics, now with uv green aditive:
http://img.photobucket.com/albums/v2...u/IMG_3514.jpg
http://img.photobucket.com/albums/v2...u/IMG_3515.jpg
http://img.photobucket.com/albums/v2...u/IMG_3522.jpg
http://img.photobucket.com/albums/v2...u/IMG_3526.jpg
cpu: i7-920 d0 w/ t56 v3 @ 4ghz
mb: ex58-extreme
ram: kingmax elpida 3x2 w/ nexus hxr-5500 @ 1600mhz
vga: gtx-285 w/ ek wb
psu: hx620
http://pc-style.hu/word/wp-content/u...9/09/br4d3.jpg
http://pc-style.hu/word/wp-content/u...9/09/br4d6.jpg
http://pc-style.hu/word/wp-content/u.../09/br4d12.jpg
for other pics click here.
cheerz!
oh, i forget... here's a fast shot w/ flash:
http://img19.imageshack.us/img19/4849/br4dvaku.png
Nice job Pisti :up:
thank you szik. :rolleyes:
