Originally Posted by
Linuxfan
The motherboard apparently has an FSB hole which I was running into when I tried to take baby steps from 5.15ghz to 5.3ghz in the OS. All I do now is boot it at 5ghz and then set it to 5.5ghz with ET6. Works great and is very stable at 5.5ghz. :D
Same settings as I used to use for my Wprime, SuperPi, and Pifast runs at 5.6ghz. Didn't change ANY settings other than the MCH core and the CPU core. :up:
Anything I should change that would help the temps, stress the CPU less, or make it more stable? :shrug:
Its running stable enough right now at 5.5... since I'm board limited and can't go over 5.61ghz with the board, it might not matter to change anything else... :ROTF:
