^ i think the n45 chips can handle a bit more temps then other chips? im kinda stubborn to reduce my vcore :D , cuz i know it will NOT post
is the latest bios for p5q pro = v 1307???
heres my screenshot
http://i38.tinypic.com/2uyhwk6.jpg
cheers
heres my screenshot
cheers
For the love of god stop asking what the latest mBIOS is their all listed on the first page and its very self explanatory! *deep breaths*
Well, after about the zillionth PM\MSN msg\ asking in this thread, it wears a bit thin somebody asking what the latest mBIOS is :p:
That was classic. :up:
...and if that happens I turn green screaming "Hulk SMASH!" :p:
Hi Ket. What's the latest mBIOS for P5Q-E? Can you make me a custom one which magically makes my CPU do 6GHz?
Thanks. I look forward to your next mBIOS release. I appreciate your work, it's awesome.
Hi Ket. Is my mBIOS ready yet?
Look forward to hearing from you.
Lmao @ Dee.
So True :ROTF:
:p:
R O F L !
Any idea how to get 4500Mhz stable with my pc specs? i kinda get it stable with 10x450 but not with 9x500, not sure what voltages to set.
Anyone broken 600MHz FSB on this board? Or should I be looking at a different board for that?
I'm sure its possible with the right hardware. FSB largely depends on your CPU and settings. Mainboards are rarely the cause of FSB walls in the grand scale of things.
I did a quick search but didnt find anything. Are there any modded bios for the p5q ws workstation board?
The latest bios on Asus' page is version 1307
Would the mBIOS 1307 for the P5q or P5q Pro work with this board?
If the board hasn't been talked about, theres no mBIOS for it.
Hi Ket,
I play with m1307 for days and have some fun. After flashed the 1406, it boots with ASUS logo? I did clear BIOS (jumper and took battery out) but ASUS logo stay still. Without that dragon I'm not sure if I using mBIOS? What do I missed Ket?
I just didn't change the boot logo for the 1406m versions as I still wasn't fully up and running when I done them, your not missing anything with the 1406m versions apart from the custom logo ;)
Hey guys, my abit ip35pro finally died after like a year so I ordered one of these p5 pro boards. One question does it have a full reboot after you change any bios settings like some of the P35 and earlier boards do.
