May I know if the figure(s) in the "Results" column matter when it comes to stability? i.e. I'm able to complete 25runs of IBT using different OC settings, but sometimes I get 2.something instead of the more "common" 3.something in the results column. Does that make a difference?
Also, since I can complete IBT on a few different set of OC settings, I should use the one that takes the shortest time per run & give the highest Gflops right?
