TPower I45, Q6600 @ 480x7, 1152MHz memory - Page 1 of 3
BIOSTAR TPower I45, 07/10 BIOS
480x7, Memory 1152MHz
Q6600 - Thermalright Ultra-120 Extreme
2x1GB OCZ Reaper PC2-9200 1150MHz 5-5-5-18
EVGA 8800 GTS 512
Yellow Slots Used For Memory
This CPU tops out around 3850MHz stable but requires a lot of voltage. I had intended to run the CPU using the x8 multiplier but on air this turned out to not be possible. Running Linpack the cores were hitting 96C - 98C which is why I settled with the x7 multiplier. Using the x8 multiplier the board was able to pass the other benches. The board also had no issues running the memory at its rated speed.
click for larger image
http://www.edgeofstability.com/image...ios/main_s.jpg http://www.edgeofstability.com/image...ios/volt_s.jpg
http://www.edgeofstability.com/image...os/dram1_s.jpg http://www.edgeofstability.com/image...os/dram2_s.jpg
http://www.edgeofstability.com/image...os/clock_s.jpg http://www.edgeofstability.com/image...ios/cpu1_s.jpg
http://www.edgeofstability.com/image...bios/cpu_s.jpg
Code:
CPU Configuration Page
C1E Support...............................[Enabled]
Hardware Prefetcher.......................[Enabled]
Adjacent Cache Line Prefetch..............[Enabled]
Max CPUID Value Limit.....................[Disabled]
Intel (R) Virtualization Tech.............[Enabled]
CPU TM function...........................[Enabled]
Execute-Disable Bit Capability............[Enabled]
Core Multi-Processing.....................[Enabled]
Intel (R) C-STATE tech....................[Disabled]
Main BIOS Page
Over-Clocking Navigator...................[Manual Overclock]
Intel (R) SpeedStep(tm) tech..............[Disabled]
Ratio CMOS Setting........................[ x7.0]
CPU Frequency Setting.....................[480]
Over Clock Retry Couont...................[1]
FSB (Bsel) To Northbridge Latch...........[FSB 1333]
FSB Compensation FineTune.................[Enabled]
DRAM Frequency............................[DDR2 1152Mhz]
DDR2 Enhance Mode.........................[Enabled]
> DRAM Timing Configuration...............Listed Below
> Clock Gen Configuration.................Listed Below
> CPU Configuration.......................Listed Below
> Voltage Configuration...................Listed Below
Memory Test............................ ..[Disabled]
DRAM Timing Configuration Page
DDR2 RCOMP Configuration .................Configuration 2
Static tREAD Value(PL)....................7T
Configure DRAM Timing by SPD..............Disabled
DRAM tCL..................................[ 5]
DRAM tRP..................................[ 5]
DRAM tRCD.................................[ 5]
DRAM tRAS.................................[15]
DRAM tWR..................................[ 6]
DRAM tRFC.................................[36]
DRAM tWTR.................................[ 5]
DRAM tRRD.................................[ 3]
DRAM tRTP.................................[ 3]
Write to Precharge Delay..................[13]
Read to Precharge Delay...................[ 5]
PrechargeAll to Act Delay.................[ 5]
PrechargeAll->Refresh Delay...............[ 5]
R-to-W Delay..............................[ 8]
R-to-R Delay(Same Rank)...................[ 4]
W-to-W Delay(Same Rank)...................[ 4]
W-to-R Delay(Same Rank)...................[11]
Refresh Counter...........................[3120T]
COLOR="Red"]Clock Gen Configuration Page[/COLOR]
PCIE Frequency Setting....................[100]
CPU Clock Skew Control....................[ 200ps]
(G) MCH Clock Skew Control................[ 400ps]
CPU Clock Driving Control.................[Auto]
Voltage Setting Page
CPU Voltage...............................[+0.150 V]
DDR Voltage...............................[Auto]
Chipset Voltage...........................[+0.225 V]
FSB Voltage...............................[+0.225 V]
CPU Core1 GTL Ref Voltage.................[0.67*VTT]
CPU Core2 GTL Ref Voltage.................[0.67*VTT]
MCH GTL Ref Voltage.......................[0.64*VTT]
CPU PLL Voltage...........................[1.6 V]
http://www.edgeofstability.com/image...r_lin_64_s.jpg
TPower I45, Q6600 @ 480x7, 1152MHz memory - Page 2 of 3
TPower I45, Q6600 @ 480x7, 1152MHz memory - Page 3 of 3
