I like it iad :)
I like it iad :)
Wow, very nice System and neat wire-managment. :woot:Quote:
Originally Posted by Roger_D25
Have fun with your new rig :)
Five-Seven,
Thanks for the great comments, much apprecaited! Since I posted those pictures the other day I've added a second 120.3 radiator but I'm not sure how long I'll keep it installed because it didn't lower my temps at all? I'm not exaclty sure why, I assumed adding a second huge radiator like that would have lowered temps by at least a few degrees under load but no go.
If anyone has any ideas why this might be the case please feel free to post! Also feel free to post suggestions on how to install the radiator differently for lower temps? Here are a few pictures of the new setup.
http://img403.imageshack.us/img403/4632/radiatorec5.jpg
http://img443.imageshack.us/img443/2...ngbegunqq5.jpg
http://img262.imageshack.us/img262/5...inebabyxt5.jpg
Hey iadstudio... How's that Scythe Mine keeping your E6700 cool?? 'cause I've got heat-problems with mine on the specs in my sig (hitting ~65'c)Quote:
Originally Posted by iadstudio
Best Regards :toast:
Ha ha Roger, I like the make-it-fit Borg approach (you will be assimilated) with the raddy. I hate when raddies won't fit the back of cases. Nothing a jackhammer won't fix. :lol:
WRT lower temps, add some fan shrouds. Better performance and quieter too. Sidewinder Computers is usually cheapest.
Edit: You didn't post temps. Maybe you have already reached your sweet spot? Can't go past ambient no matter how many raddies. If not, try more flow.
Thanks for the suggestions uclajd, much apprecaited! I suppose it would have made sense to post some temps, lol! At the moment I'm running at 3.7Ghz on 1.49v (actual voltage w/DMM) and idle temp is 39C-42C, my load temps are 58C-64C depending on how my apartment temp varies over the night (I read load temps after a few hours of Orthos Small FFT's) and apartment temp varies around 23C. So unfortuenlty I'm no where close to ambient!
Was I a total idiot to think the temp would have dropped a few degrees by adding that crappy BIP120.3? I realize it's not much compared to the PA120.3 but it certainly added some surface area right? I should go back and re-read some of Marci's threads/post to get a better idea of why this didn't help bring temps down a bit!
I was pushing 62+ before I got the airflow worked out. If you look in the first picture I replaced one of the drive bay covers with modders mesh. Gives me much better airflow through the scythe Mine. Temps max out at 54c now.Quote:
Originally Posted by DTU_XaVier
That's the one down side of the Antec case, It's quiet but not enough air intake. All good now!
Just make sure your airflow is flawless.
a few pics of my budget box.
http://i18.photobucket.com/albums/b1...interior-1.jpg
http://i18.photobucket.com/albums/b1...nternals-1.jpg
You might want to think about resizing pics... most people don't browse the internet @ 1600X1200...Quote:
Ya I agree, you should post at 1920x1200. Things look much better on my 24in LCD at that res.Quote:
The second rad probably hurt the flow enough that the extra area didnt' really make a difference.
That pa120.3 probably has the water getting very close to ambient anyway. To get a reasonable idea of what the water temp is, undervolt the cpu and see what it idles at, that should be within around 5 degrees of the water temperature(or at least it was on my machine)
Sorry guys about the big picture size, I usually post at 1024 x 768 but if there is anything to read in the picture you can't read it because it's just too small! I also forget sometimes because I have a 24" LCD.
smopoim86,
Thanks for the post, back before I added the BIP120.3 and only had the PA120.3 my idle temps with CPU at stock speed and 1.19v was 20C-23C (depending on my apartment temp) so it was almost exaclty ambient. The actual water temp was also about 20C-23C (again depending on apartment temp).
I will bring my current CPU back to stock speeds and lower VCORE, then measure temps with both radiators installed to see what happens. In anycase smopoim86 if my idle temps are around ambient with CPU undervolted (like it was before I added second rad) what does that mean? Does that mean that the radiator was cooling the water as much as possible (ambient) so it wouldn't matter how many radiators I added (it can't get lower than abient)?
One last thing to add, my CPU temp didn't get any lower even though I took the G80 out of loop? My idle/load temps stayed right where they were when the G80 was in the same loop. Does that tell you anything?
I have the Scythe Mine on a E6600 @ 3.4GHz with 1.375V
When it is priming, my temps are max. 48°C for Core 1 and 49°C for Core 2
When my PC ist idling , i got temps around 30°C fore Core 1 and 31°C for Core 2 .. Its like a Watercooling :eek:
You can see my Case and my Aircycle in my signatur in sysprofile :)
my highest delta with the mine on an overclocked (4.2-1.4volts) 640 was 12 degrees. ( a sunon highspeed fan undervolted to just above 5volts barely turning). 42-3 idle 54-55 maxQuote:
Originally Posted by AMD_Deluxe
At max speed i was getting an eight degree delta.
my mount was flawless (small change in ac5 would yeild an almost 3degree difference in temps. one degree lower is what i've ever seen on a normal basis with that cooler and chip) and my cpu lapped.
you must be doing something wrong.
What am I doing wrong ???
sry ma english isnt very well xD
My last mod:
http://www.pctuner.info/test/results...8_S7000007.JPGhttp://www.pctuner.info/test/results...4_S7000009.JPG
http://www.pctuner.info/test/results...4_S7000010.JPGhttp://www.pctuner.info/test/results...1_S7000006.JPG
http://www.pctuner.info/test/results...2_S7000011.JPGhttp://www.pctuner.info/test/results...3_S7000013.JPG
http://www.pctuner.info/test/results...6_S7000016.JPGhttp://www.pctuner.info/test/results...8_S7000018.JPG
I'm not sure you are doing anything wrong. Are you using coreTemp to determine the temps you posted? One thing that may be helping is the case layout. The air intake you have on the side of the mobo really helps. WHen air comes in from that side of the case it'll flow behind the mobo as well and really drop your temps. 30c for idle temps though seems pretty low for air.Quote:
Originally Posted by chensen78
What kind of case is that?:)
Lian Li PC2100?
Lian-Li PC-V2000B?
Lian Li V2000 Plus II :D
http://img254.imageshack.us/img254/8126/img3258hf7.jpg
my old red chieftec cs-601. :woot:
yes it was a question rather since if your mount is good and you have good airflow your delta should be alot lower no matter your ambient (to a degree-->no pun intended)Quote:
18 degrees suggest you have a bad ihs or you either dont have enough, or too much tim.
just a thought. you seemed proud of your temps with that cooler, i'm saying it could even be better.
yes i think so , too ...
seems so that the spreader of my cpu is bad ..damn it ! i have to sand it ^^
Let's get it over with! ^^
